Rocker Cover Breather Dash -10 and -12 size, they replace the stock breathers by push-fitting them, instead going to the hassle of welding breathers or AN adaptors to rocker covers.
Made from CNC Aluminium, and replace the standard rocker cover breathers so you can use a screw on fitting like Speedflow/Earls/PFE etc
These are a tight fit so they will never leak and won't come loose once installed.
Suits RB20, RB25 and RB26.
RB26 size available in -10 or -12
RB20 and RB25 -10 size only available
-10 size are $50 a pair - including postage.
-12 RB26 are $55 a pair - including postage.
PM if interested!
pics....
-10 on RB25 rocker covers
-10 RB25 and RB20
-12 RB26 fitted
-10 RB26 fitted
-10 on RB20
-10 RB26
-12 RB26
  • Like 1
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
Performance Imports magazine has my -12 RB26 breathers in the GTR cover car this month! - issue 171.
There are good pics showing how they look with fittings attached.
  • 1 month later...
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
