Up for sale is my Pride and Joy Immaculate R34-GTT which I have owned for around 6 years now.
This car has always been 100% reliable entusiast vehicle, regularly serviced and treated like a baby. The car is currently a weekend car and has seen minimal use in the last 2 years. The car is regularly polished and waxed and kept inside a garage. It will be sad to see it go and will be missed dearly. The car is a beautiful example, any genuine buyer who views the vehicle will not be disappointed.
The car produces 265kw at the wheels (Tuned by Jim at Tunehouse), A full timing belt kit (+ all belts) has just been performed by Tunehouse + alot of other service work including a compression test which was done before the larger turbo was installed receipts included). Alot of the parts are high end direct fit Jap items to ensure they fit correctly and are reliable + having a near stock under bonnet appearance so there is never any unwanted attention.
Motor : R34 GTT GCG Ball Bearing Highflow, ARC Return Flow FMIC, Z32 AFM, Deatschworks Hi Flow injectors, Apexi Power FC + Hand Control, Apexi Electronic boost controller, Xforce 3inch Stainless turbo back exhaust with high flow cat, Tomei in tank direct replacement hi flow fuel pump, Silicone intake pipe AFM to Turbo, GFB Stealth FX adjustable BOV, Custom Aluminum radiator cooling panel, Greddy Catch can ,Blitz High flow panel filter ,Splitfire coilpacks, Apexi pod filter kit also included.
Suspension: Greddy Type S Coilovers Greddy EDFC control unit for coilovers (not fitted) Whiteline F + R adjustable swaybars Whiteline subcradle bushes Urethane castor rod bushes Cusco Rear strut brace Interior: Nismo gear knob Genuine Nissan GTR V Spec Aluminium pedals Apexi Turbo timer Clarion head unit (cd/MP3+ USB connector in glovebox) Clarion bluetooth kit Pioneer JDM carrozzeria speakers F+R
Exterior: Nismo Eyelids, Nismo Clear front & side indicators, Starcorp Impul rims 18” Nismo copy front lip
Driveline: Excedy 3 puk ceramic clutch (sprung centre) Genuine C's Short shifter, Custom Urethane gearbox mount
The car has just ticked over 100,000 kms and is priced to sell at:
$19,500
Pm or call me on 0402 219 14(two)
  • 3 weeks later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
