On Friday arvo I took the car down to Boost Worx to do the usual oil & filter and diff fluid change. While I was there we also did a muffler change (I'd been keen to do it for a while).
I now have a straight-through N1 style muffler with the drift spec angled tip (looks very cool). The original Trust pipework went under the diff with a nasty angle that undoubtedly robbed power. It wasn't a lot of power, but still worth the change. Unfortunately during the dyno runs we discovered that from 6000rpm and up it was getting dangerously lean (13.0:1) Up till 6000 it sits at low 12's.
With a peak of 1.5bar it made 297rwkw at 5500rpm (well before it started to go lean). In fact back to back runs netted 292, 295 and 297rwkw. On Wednesday we're going to check the filter (fairly new - shouldn't be blocked?) the tank pick-up (might be blocked?) and then the pump itself. If need be a new 044 will go in. It is 100% before the fuel rail, as we took off the return line and watched the flow drop to buggery as the revs climbed towards 6000rpm.
I might just crack the 300rwkw mark yet? :) Shaun kept putting more fuel in up top and it continued to make power (292-295-297). So once the fuel pressure issue is sorted and we can get it back into the low 12's/high 11's at 6400rpm (were it usually makes peak power) it should be interesting.
https://www.sau.com.au/forums/topic/42158-exhausts-noise-s-power/
Sorry Matt, but I gotta do this - told you so:p:D
Good to hear, how is off boost and spoolup? Mine came in a lot harder and earlier when I ditched the old exhaust, as well as crisper off boost. What fuel pump are you currently running? Have you consider the Tomei in tank pump? they can be had for pretty cheap these days, only a bit more than the bosch, and they are a straight fit without rooting around.
Come on Matt, give us the full story instead of just teasing:)
Hmmm I would have thought pushing 13:1 ratio down to 12 wouldnt get you any more power at all? I reckon 1 more degree of ignition timing at peak power RPM will get you 300rwkw since your so close :( Otherwise, drop the exhaust from the cat back and try again! Haha j/k ;)
Thanks Lach'. Yeah I'd love to do cams mate! But no money for them atm :( I actually rang your Mobile while I was at BWX, but it went straight to msg bank.
How does it sound? Very very angry! 'Tuff' would be a good description :( The down side is it's much louder, and therefore attracts more attention. You can't have everything though (without one of those exhaust flap thingy’s).
Yeah yeah Steve ;) But I don’t mind you giving me the ‘I told you so’, ‘cause it was you that convinced me to do the exhaust swap in the first place.
Off-boost and spool haven’t seemed to change that much? On the dyno sheet there’s only a few extra kw in it. Basically, up till ~4000rpm it’s not much different. But from 4,000 to 5,500 (and no doubt till 6,400 once all is ok) it out powers the old system, by upto 20rwkw in some places! The peak gain is only minimal (6rwkw).
I thought I had a 044 (200 lbs/hr), but it may well be a 984 (165lbs/hr) Even the 984 “should” easily handle 300+rwkw. The 910 (130lbs/hr) can cope with 300rwkw. I’m hoping it’s just a clogged strainer that has only just started to show up due to the extra demand.
I hear what your saying Busky, but I watched Shaun opening up the duty cycle and putting more fuel in and it was making MORE power rather than less. The good thing is, it makes high 290’s at just 5,500rpm and that’s with low 12’s A/FR. Peak torque is at ~4,400rpm.
Once we get the pump issue sorted I’ll scan the resulting dyno sheet for all to have a gander. Stay “tuned” :D
Thanks Greg. If you don't mind the extra noise it's well worth it mate.
With a less restrictive exhaust and nice cool air temps you'll probably hit the magic 300. Get some Nittos and then see if you can't bag yourself an 11sec 1/4. I'm hoping to prove my theory on June the 6th.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
