I've searched and can't find what i'm after.
i've done the reverse lights in the eng bay and on that plug there are 3 green wires.
on the ecu side, pin 44 (neutral switch) is green/pink.
does anyone know which pin/wire it is on the eng bay plug? I'm assuming it is one of the wires on the plug that I have reverse hooked up to.
goign to try a continuity test from ecu to that plug tonight, if my DMM leads are long enough.
also, on the neutral switch on the gearbox, does it matter which one is +ve and -ve or is it the same as reverse and can go either way.
https://www.sau.com.au/forums/topic/421631-r32-auto-man-neutral-pin-44-ecu/
Just get the R32 GTR service manual. The wiring diagrams for RB20 stuff are in there too. Then all the wire colours and pins are there for the taking.
Failing that, if you do use a multimeter to cont check it, and the leads aren't long enough......just add some length to the lead with a spare bit of wire and some crocodile clips (or twist and tape).
