if you have a hard table or something, sit on it with ur legs hanging over the side, put a cricket ball or a golf ball under your hammys and basically do the same movements as the foam roller.
hurts a lot more, but helps relieve some pressure.
is there an echo in here?
After a weekend on the car I was pretty stiff last night so I had a good session making love to the foam roller and stretching, my right quad was so tender I couldn't put all my body weight on it without breaking out into giggles (what I do when something is uncomfortable).
Hammy is still niggling this morning but I managed to on/off jog half of the morning walk so we'll see how Gym goes tonight.
I think I underestimated how much a weekend on the car took out of me as tonight was a little bit of a struggle, still got an extra rep here and there.
Squat low bar
3x8 80.5 90.5 100 (6)
one extra
Bench
3x8 93 101.5 106.5 (7)
DL barefoot
3x8 88 97.5 104
got'em all but it was hard yakka and average form on the last rep.
Row
3x8 78 88 93
as above
Chins
3x8 7.5 12.5 15 (6)
Dips
3x8 15 20 25
Little bit of an update.
Wen to the physio yesterday, she didn't test me on anything but was happy that I'd started jogging again and had been stretching the bad leg calf more, she's given me another more challenging stretch to do and commented that I did not get enough ROM work during my early recovery days and that we'll have to get stuck into that now. I would say my ankle ROM has improved since doing her specific stretch.
She put me on a few balance boards and I was pretty terrible at it, not much worse than her, but she said someone with a high level of activity like me should have better balance and stabilisation and that it was indicative of poor (the word escapes me right now) but awareness of my foot/ankle position and location in space so to speak. I admit I had much better balance before destroying my ankle.
When I go back she's going to put me on the treadmill and check out my running style and see what she can do mechanically as I know my gait is not even and my legs do not drive/operate the same both sides which I can feel most notably when squatting.
She gave me a bar and had me show her my DL technique and said it was quite good, so BAM.
As for gym last night, this getting back to 3x8 is hard yakka lol but got a little further.
Squat low bar
3x8 80.5 90.5 100 (7)
One extra.
Bench
3x8 93 101.5 106.5 (7.5)
I thought I had 8 in me but as I came down for it Kate walked in with Ella to talk about something and it broke my concentration so I stopped half way and racked it, that chat took 30 seconds or so then I busted out one more rep.
Bench is always the hardest for me to go an extra rep as there's the risk of being caught under the bar, you can get out but it's annoying, the safeties on my rack are a touch too heigh at one point and a touch too low on the next point down.
DL barefoot
3x8 88 97.5 104
got'em again so will look to add some weight shortly
Row
3x8 78 88 93
As above
Chins
3x8 7.5 12.5 15 (6)
Tried for a 7th but didn't have it.
Dips
3x8 15 20 25
Will look to add here.
Also, Kate has a mirror in the gym room now as she's been using the lat pull down attachment to help with some of her physio after the birth and as I was shirtless from being hot during DLs, I took a snap for comparisons sake.
As you can see I could stand to drop a little weight/bf % in the mid section but for someone who doesn't stress too much about diet and isn't running like I was I'm not super unhappy at the moment. Given I no longer do any ab work and haven't for months and months I could be in worse shape. Forgive the facial expression, I was trying not to breath as it was already hard enough to get a non blurry photo given the average iphone camera and the lighting.
Cheers.
I forgot to add, that after jogging say 70-75% of the walk this morning and having gym'd last night my ankle is a bit tender up the inside so I'll just keep taking ti slowly.
I also used shoes last night for DLs as the physio said it might be a good idea to stop my bad ankle rolling in and it seemed to help.
So I've ordered these, not for that price,m but not much cheaper either =\
Physio said it should help with squatting and running, We'll see if it helps.
http://www.2xu.com.au/mens/compression/socks/compression-sock-for-recovery-ma1955e.html
This morning I managed to jog 1.5k of the 2k run continuously, albeit at a slow pace. This was the view when I got back home, not a bad start to the day.
Forgot to update Friday night. Some progress.
I've figured that to get anywhere weights wise I will have to just keep adding weight for a bit so if I can get a solid 6-7 out in the final set I'll do that for a week (3 sessions) then add some more slowly.
So I added to a few things.
Squat low bar
3x8 80.5 90.5 104 (5 pause 6)
I was happy with that, my previous best was 5 reps at 105 so 6 reps at 104 wasn't bad, I had to really suck in some air after the 5th rep to get the 6th and I only just made it but I'm glad I backed myself to do it and got there.
I'll be adding a board under my heels tonight which I'm hoping will help ankle rom.
Bench
3x8 93 101.5 109 (6 pause 7)
I wasn't sure if I had the 7th in me continuously so I just racked it for 10 seconds and grabbed another rep, this is something else I'll be doing more of on some things.
DL barefoot
3x8 88 97.5 109 (7)
Was pretty happy with 7 reps after a 5kg increase, the 7th rep was a ball breaker though. Will sit on that weight this week as the body adjusts.
Row
3x8 78 93 97.5
Accidentally did 93 as the second set so went for some more on the final set, got'em but still unhappy with form so will keep playing.
Chins
3x8 7.5 12.5 15 (7)
Getting the 7th rep was real hard work, I really had to go for it and just scrapped it in.
Dips
3x8 15 20 27.5
Getting harder to get them all now but still managed it.
I'm finding that cardio is hurting me, as in when squatting I run out of breath/power and need to suck in more air. Getting back to running will help that I hope. Plus it's only been 3-4 sessions since moving back to 3x8s.
I'm regularly weighing in at 88kg in the mornings and my legs have definitely gotten bigger but I'd like to trim up my mid section a bit, again hopefully running will help that a bit.
Edited by ActionDan
Squat low bar
Bench
DL barefoot
3x8 88 97.5 109 (7)
Row
3x8 78 93 97.5
Chins
3x8 7.5 12.5 15 (7)
Dips
3x8 15 20 27.5
Eating less will help that last point as well.
Are you calling me fat kent? lol
Yes I know but eating less is also counter productive to strength gains, I've always been the type that prefers more exercise to less eating :)
Hi Dan
Well done on the weight increases with the squat, bench, row and especially deadlift; an increase of 5kg, wicked :)
How are your injuries going? I had acupuncture on Friday, was interesting. In a lot less pain today.
Good news about the acupuncture.
It's an increase but it's not as I was doing more before but sets of 5 and I find 3x8s more challenging due to the added endurance.
I get more "puffed" also so I equate that with being a higher load on the respiratory system.
Injuries are so so, ankle is making slow progress and I have been really pushing the stretching on it recently which has shown gains on a test I have to do where I need to get my foot as far aware from the wall as possible while still being able to touch my knee cap to the wall.
The hammy has not seen any improvement it still just lingers. I am still foam rolling and stretching but will book in to see my preferred Myo for a decent session and see if that helps.
A real mixed bag last night. I thought being Monday I would crush it like a boss but not so.
Squat low bar
3x8 80.5 90.5 104 (4 failed 5)
I added the board under my heels and its completely changed the dynamics of the squat for me. 90 felt really good mechanically but at the same time I felt like I was lacking power, as I'm now relying on different muscles more to get out of the hole, I'm guessing I'm having to push from the heels more and by my own admissions was using the middle of my foot before.
I couldn't believe I was struggling at 4 and took a few big breaths and went for 5 knowing I'd likely fail, I did and I dropped the bar off my shoulders onto the safety which I said I'd be doing more of, going to failure. The only thing I forgot to do was re-rack it and then go one more rep or so, but I don't have the strength to lift it off the safeties in a clean/jerk motion and put it back on the pins with out taking weight off it so I just put it on the next pins ready for bench.
Bench
3x8 93 101.5 109 (6 failed 7)
I actually went for this and came ever so close, maybe 30mm off the pins but I just didn't have it, a spotter would have been great. So I now know the safeties are only high enough at about my abdomen, I'm not sure what to do here as the next height up is too high.
Anyway, after re-racking the failed 7th rep I jumped back on and pushed it out.
DL barefoot
3x8 88 97.5 109
Got 8 reps on this, again struggle street on the last 2 reps but got it. Will get it again a few more times before adding.
Row
3x8 78 88 97.5
Fail city on the rows, I managed to "do" the reps but they were ugly. I've been playing with bar location in terms of where I pull it up to. I may have to move these away from the DLs as the DL works so many of the same muscles that rows suffer.
Chins
3x8 7.5 12.5 15 (7 failed 8)
The 7th rep was hard again but easier than last time so I went for an 8th knowing I wouldn't make it, I would have maybe got half way back up.
Dips
3x8 15 20 30 (6 failed 7)
The increase in weight meant for the first time in ages I failed at this so now we know roughly the limits of my dip.
So yeah a mixed bag all round but I'm committed to failing more and adding more where I can and we'll see how it goes.
No walk or run this morning, such a shit sleep =\
Edited by ActionDan
Not at all, just stating the obvious.
Steady state cardio is counter productive to strength gains as well from some views.
Also, consuming less energy vs burning more energy is the same thing = less energy in the body.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
