I've had dry needling twice and it helped.
I went to my physio on Friday (not the myo) and he agreed that it's nerve pain, likely from lower back impingement.
I'm back into the nerve glide movements and stretching.
Edited by ActionDan
Brief update, after a very busy weekend my leg nerve/hammy was really giving me grief last night, really twinging hard everytime I got up/moved around.
Had a really good stretch and did some nerve glide exercises (feet pointing and head tilting to move nerves through the sheath) which helped a biut but it's still unhappy today.
Pretty confident it's coming from my lower back too.
My guess is you have hurt your back (lower spine) or it may be piriformis sydrome, this can occur 'without' the knot in the muscle. The sciatic nerve is responsible for what you have either way and it's being messed with.
I'll keep working on it, you just keep sloggin away til you find the root cause then change whatever you need to to avoid it. We've all had enough injuries to know how this goes.
Just annoyed that there was no "clear" cause or instant where I can think of. May just be poor technique squatting or bad mechanics in my pelvis from bad rom in various joints.
surely you can get scans or whatever to find out 100%
i am all through pushing past a ningaling injury, but if that is not what it is then you need to sort it asap dude
I'll make that call soon.
It probably sounds worse than it is, it's a nerve pain in the lower hammy area, above the knee that comes and goes with movement.
Physio has just given me new exercises specifically for nerve issues, glides, leg raises, etc so we'll see if that helps or aggravates it.
I'm convinced my leg issue is actually a lower back issue, like right down low above my butt crack.
I've been paying close attention while doing the work the Physio asked for and I'm really noticing some tightness and discomfort in there.
IF I have no success there, I'll see a podiatrist and have a proper gait analysis done to check out my mechanics.
I've never had back or pelvis issues in my life until busting my leg.
But to be fair, I'd never done squats or DLs either, only ever running and lunges.
Back, no immediate relief.
She took xrays to examine and said I had a functional leg length difference (only notable when not standing/loaded up) which implies soft tissue discrepancies - no surprises there. Also my pelvis is tilted forward, putting pressure on the lower disc(s) which she feels may be impinging the nerve, she also showed me that the second lower disc when looking from the front is not sitting even, so there are other imbalances in my pelvis. Also noted that my bad foot wants to rotate outwards and roll inwards, which could be a cause or a symptom of pelvis issues.
She made some "adjustments" on some special contraption of a table but I didn't feel much going on. The table raises up in sections then she pushes down and the table drops down and resets.
Keep stretching, keep walking, jogging if I want and can tolerate, no weights for now (as in squats/DL), do light core work, planking etc.
Going back in a week to see if there's any difference, if not she concurred with my plan of attack of seeing a podiatrist next.
I don't follow the first part?
I've had a full week off gym as of today, done nothing since that last session.
I didn't make 8 last time so I'll see if I can at least get 8-9.
After that though?
I'm in two minds now, have lost a lot of momentum and interest in gym in general not being able to do squats/DLs and trying not to do anything that upsets my back/leg.
So I'll see how I go tonight with the bench, if I can get 8-9 continuous then good, but after that I might drop back to a weight where I can get out 3x8s and settle on that.
That said, if I was "going for it" tonight, regardless of if I do or don't make 8+ continuous reps, would the total reps normally go up?
That is, when you were doing it, did you just keep adding reps to the total until you started seeing improvements in the continuous phase or were you just adding more and more weight every time.
To keep it simple Dan. Pick what you 'want' to do for Bench for tonight. You might do what you used to do , you might try something else.. But, pick something you 'want'. You can challenge yourself if you 'want' or you can make it comfortable. You choose this time for yourself.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
