I've had dry needling twice and it helped.
I went to my physio on Friday (not the myo) and he agreed that it's nerve pain, likely from lower back impingement.
I'm back into the nerve glide movements and stretching.
Edited by ActionDan
Brief update, after a very busy weekend my leg nerve/hammy was really giving me grief last night, really twinging hard everytime I got up/moved around.
Had a really good stretch and did some nerve glide exercises (feet pointing and head tilting to move nerves through the sheath) which helped a biut but it's still unhappy today.
Pretty confident it's coming from my lower back too.
My guess is you have hurt your back (lower spine) or it may be piriformis sydrome, this can occur 'without' the knot in the muscle. The sciatic nerve is responsible for what you have either way and it's being messed with.
I'll keep working on it, you just keep sloggin away til you find the root cause then change whatever you need to to avoid it. We've all had enough injuries to know how this goes.
Just annoyed that there was no "clear" cause or instant where I can think of. May just be poor technique squatting or bad mechanics in my pelvis from bad rom in various joints.
surely you can get scans or whatever to find out 100%
i am all through pushing past a ningaling injury, but if that is not what it is then you need to sort it asap dude
I'll make that call soon.
It probably sounds worse than it is, it's a nerve pain in the lower hammy area, above the knee that comes and goes with movement.
Physio has just given me new exercises specifically for nerve issues, glides, leg raises, etc so we'll see if that helps or aggravates it.
I'm convinced my leg issue is actually a lower back issue, like right down low above my butt crack.
I've been paying close attention while doing the work the Physio asked for and I'm really noticing some tightness and discomfort in there.
IF I have no success there, I'll see a podiatrist and have a proper gait analysis done to check out my mechanics.
I've never had back or pelvis issues in my life until busting my leg.
But to be fair, I'd never done squats or DLs either, only ever running and lunges.
Back, no immediate relief.
She took xrays to examine and said I had a functional leg length difference (only notable when not standing/loaded up) which implies soft tissue discrepancies - no surprises there. Also my pelvis is tilted forward, putting pressure on the lower disc(s) which she feels may be impinging the nerve, she also showed me that the second lower disc when looking from the front is not sitting even, so there are other imbalances in my pelvis. Also noted that my bad foot wants to rotate outwards and roll inwards, which could be a cause or a symptom of pelvis issues.
She made some "adjustments" on some special contraption of a table but I didn't feel much going on. The table raises up in sections then she pushes down and the table drops down and resets.
Keep stretching, keep walking, jogging if I want and can tolerate, no weights for now (as in squats/DL), do light core work, planking etc.
Going back in a week to see if there's any difference, if not she concurred with my plan of attack of seeing a podiatrist next.
I don't follow the first part?
I've had a full week off gym as of today, done nothing since that last session.
I didn't make 8 last time so I'll see if I can at least get 8-9.
After that though?
I'm in two minds now, have lost a lot of momentum and interest in gym in general not being able to do squats/DLs and trying not to do anything that upsets my back/leg.
So I'll see how I go tonight with the bench, if I can get 8-9 continuous then good, but after that I might drop back to a weight where I can get out 3x8s and settle on that.
That said, if I was "going for it" tonight, regardless of if I do or don't make 8+ continuous reps, would the total reps normally go up?
That is, when you were doing it, did you just keep adding reps to the total until you started seeing improvements in the continuous phase or were you just adding more and more weight every time.
To keep it simple Dan. Pick what you 'want' to do for Bench for tonight. You might do what you used to do , you might try something else.. But, pick something you 'want'. You can challenge yourself if you 'want' or you can make it comfortable. You choose this time for yourself.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
