I have a unitig ac/dc 200amp thats a couple of years old now. Like already said, cant fault it. Welds great and heaps of functions to control everything. My hand piece has a wheel (like a mouse wheel) to control amps too.
Really great welder, so much that im looking at getting a unimig mig welder when the time is right
https://www.sau.com.au/forums/topic/421721-tig-welders/#findComment-6791354
I used to have a unitig200 as well.. was a great machine but have since moved to a token tools tig with a few more functions and can be had for around the same price.. The difference in weld quality was quite easy to see straight away.. Nothing wrong with the unitig whatsoever but id definitely go the token tools welder as they are pretty much the same price.
https://www.sau.com.au/forums/topic/421721-tig-welders/#findComment-6801926
is this the token tools tig you have
http://www.tokentools.com.au/prod10.htm
Yep spot on, only thing i didnt like about the welder was the torch, make sure you upgrade to the variable amp control torch.. The button on the torch i have sticks down every now and then has made a few f**kups for me haha..
https://www.sau.com.au/forums/topic/421721-tig-welders/#findComment-6802446
  • 4 weeks later...
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
