All items gotta go! Clearing space in and around my house. All items located in Fairfield, can post at buyer expense. Most items negotiable on price, the more you buy the cheaper things get.
Items sold as is and needs to go, offers accepted.
R34
Genuine damaged Nismo/Altia front bumper, repairable - $350
HKS Rear coilovers, damaged - $50
Nismo Front & Rear sway bar - $200
RB25DET Neo Starter Motor - $100
Custom 3" Exhaust & Y Split dump pipe - $200
Driver side window regulator - $80
RB25DET Neo engine cover - $20
GTT Strut brace - $40
GT Strut Brace - $20
Bonnet arm - $20
Spare Tyre - $40
Front radiator support, cut from strut tower - $150
GTT rear subframe/cradle - $100
Manual GTT Diff (center gears unknown, not bothered to open up) - $150
Sedan stock exhaust - $100
Set of 4 door trims - $50
Complete seatbelt set - $150
GTT dash, immaculate condition - $100
Auto tiptronic steering wheel - $50
Lower control arm - $80
Upper Control arm - $50
5 stud hubs - $100 each or $250 for full set of 4
Driver side Window glass - $50
Sedan driver window - $50
Sedan Spoiler - $100
Airbox with snorkel - $100
R33
Front reo bar, cut for FMIC - $50
Bonnet Arm - $20
Rear Sway bar - $20
Spare tyre - $40
Driver Guard - $50
Manual GTS-T Diff (center gears unknown, not bothered to open up) - $150
Auto GTS-T Diff (center gears unknown, not bothered to open up) - $150
GTS-T Brakes set, calipers and rotors - $400
Sedan Doors, all 4 - $150
OEM Airbox snorkel - $50
Driver side guard - $150
Snorkel on its own - $50
Motors
R34 RB25DET Neo Complete engine, no turbo no loom, runs fine, approx 101117 KMs - $1250
R33 RB25DET Complete engine, no turbo, no loom, runs fine, approx 125,XXX KMs - $1100
Gearboxes
R32 GTR Gearbox - $400
R33 GTS-T Auto Gearbox - $150
R34 GTT Auto Gearbox - $200
ECU
R34 RB25DET Neo Auto - $100
R33 RB25DET Auto - $100
Free
R34 Boot driver side sub box, GTT ONLY.
Plenty of other parts that I haven't listed, little stuff like sensors, trims, etc, I have plenty, just ask!
  • Replies 50
More photos in my Gumtree link in my sig as well, disregard the listed prices and make an offer.
Sweet mate I may have one not sure if it work though, if its sweet ill get back to ya tomorrow arvo, let ya know, cheers
hey ricky by 'set of 4 door trims' did you mean they are from a 4 door, or they are the 4 'door' trims for a coupe? pics please!
There from a 4 door mate. Haha sorry to disappoint. I'm still on the hunt for a pair of perfect condition trims for myself.
is the factory airbox just straight bolt on (remove my pod and straight bolt on the airbox?)
Yes, straight bolt on man
hi, do you have a radiator for an r33 auto?
I've got a radiator for a R33 manual, only difference is the ineffective oil cooling pipes at the bottom.
ok thanks Ricky. Was probably a stupid question hahaha. Car currently in the shop no idea when it'll be out, may pick up a few bits and pieces from you once I get it fixed up =(
what price are you after for the radiator?
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
