Just before christmas and a new baby arriving, I had my series 1 nicked from outside my house.
Got paid out for it eventually but cops found it sitting in a quiet neighbourhood, they had tried to light a fire in it and had nicked my music and odb interface cable. I'd just put a new cambelt, waterpump rear shocks and front bumper on right before it was nicked. gutted. Anyway, enough sob story:
I need a new car.
I loved the open road handling, and I'm loath to go back to something shittier.
While I'm entertaining the idea of another stagea maybe the m35 if I can afford, I'm also seeing cefiros - think they have different engines, but seem fairly similar otherwise.
Does anyone know how they handle compared to a stagea? do they have simliar chops with regards to body roll etc.
I'm not into lowered, race performance, with giant wheels, just a good family wagon that handles nicely on the road. And I like 6 cylinders.
interested to hear anyone's thoughts
https://www.sau.com.au/forums/topic/421821-cefiro-vs-stagea-comparison/
Yep get another wagon. Cefiros are smaller, lighter and should be more economical but not so good in a smash. There are plenty of RS4s for sale and even M35s are getting cheap now.
http://www.trademe.co.nz/motors/used-cars/nissan/stagea/auction-570924576.htm
http://www.trademe.co.nz/motors/used-cars/nissan/stagea/auction-574238798.htm
http://www.trademe.co.nz/motors/used-cars/nissan/stagea/auction-573529677.htm
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
