WTB: Stock Exhaust Parts R33 Gtst - Needed Soon :D
Guest RedLineGTR
Need a Stock r33 gtst exhaust (turbo back). Need the Full stock exhaust including the heatshield from the dump pipe and so on, DONT need the turbo heatshield. IF someone has a cat as well i can take it off thier hands too if need be. Looking for one in good condition without and huge dints etc. Located in MELBOURNE.
These are the parts i need from a R33 Gtst Either Series 1 Or 2.
Original Turbo Dump Pipe With Heat shield
Original Front Pipe With Heath shield
Original Catalytic Converter (CAT)
Original Cat Back Exhaust system
Please PM ME or Call me on my mobile with a price that you want for it.
0411 646 911 Names Rob. Need people in melbourne.
Thanks For your time. Rob
G'day Rob,
I've got the dump and front pipe if your really keen. The front pipe has all the heat shield stuff on it, but I don't have the heat shield for the dump.... I'm in Canberra though :)
J
Guest RedLineGTR
Thanks for that, i'm trying to find some people in vic (hopefully) if i cant find any i will have to get parts from out of vic :) if it comes to that can you pm me a price for the dump pipe to be posted to melb :) as long as the heatshield bolts back find onto the dump & all the screws thier for the heatshield.
Thanks for your time. Rob
Hey Rob, I'll have the stuff from cat back sometime this month..... waiting for my other exhaust to come in first....... I'm in Melb and will write again, when here.
Cheers!
PS, may I ask, why do you want stock stuff again?
Guest RedLineGTR
Rob, u still interested?
If your still shopping around for one :rant: & your going to be around chadstone shopping centre this weekend give us a buzz so i can check the N1 out if possible, thats only if your going past chadstone, Don’t want it to be an inconvenience cos i'm not 100% i would pop down to yours to check it out but my car isnt drivable atm (nothing serious) but it cant cant move from the garage atm.
Thanks Rob. My number is up top so give us i buzz or something on the weekend.
Guest RedLineGTR
Cheers!
Thanks for the post, i'll see if i still need it by then but keep us posted :rant:
Cheers Rob
Guest RedLineGTR
Does anyone have the Stock Dump Pipe With The Heat Shield With the Heat Shield bolted on with the Original bolts (that hold the shield on the dump) so it dosn't fall off If so pm me with a price inc. postage if interstate :P
Need One Soon. Thanks Rob
Hey Rob,
didn't you get my PM?
I have dump+front pipe all in good nick!
I never had the heat shield, so I guess you don't need those... but I also have the cat back.
I am close by in cheltenham, so PM me and let me know if you are interested. They are just collecting dust in my garage, so no reasonable offers refused...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
