I am getting a bit pissed off with a few teething problems I am having that I shouldnt be having.
I had a missfire the other day so I went to the place who did my car and gave them the 'WTF?' they played with injector plugs and it was fixed "oh yeh we had no clips to hold your plugs to your injectors you will have to get some" ... that didnt impress me because what if at full boost an injector plug gets loose? there goes my engine.... err WTF?
Now I was driving home last night and I got a missfire again, I pulled over and fiddled with the plugs and noticed under revs that a mist (looked like steam but i guess its fuel?) was coming from between the front injector and the block and there was some liquid there, it stunk of petrol.
When I first sent the car to the workshop I had put the plugs in (GTR injectors, RB20) but I didnt bed them in properly so they leaked and had to be redone, the workshop also told me while tuning an injector leaked and had to be redone again. NB. Redone = put back in with new o-ring.
I cant drive the car to the workshop as I am scared it will catch on fire.
My questions are:
1) The mist that looks like steam coming out of the injector would be fuel or steam ?
2) Anyone know the part number of the orings or if they are the same as RB30 ones so i can get some tomorrow.
3) will i need to replace all the o-rings or just one injector.
3) hints on the best way to replace and install the new oring(s)
Any other advice is welcomed.
Thanks in advance,
Evan
https://www.sau.com.au/forums/topic/42268-teething-problems/
It's the o-ring. I had a split one (was crimped when putting in the injector) for about 2,000k's. Was dribbling fuel out the whole time, too lazy to change it.
With the top feed injectors you need to loosen the fuel rail (two bolts) and remove the offending injector to get to the o ring. You can do it yourself, although the workshop that's done all the work should replace it out of courtesy (hell they should have noticed it and fixed it when they had the car).
It's a bit of a pain the the ass with the standard intake manifold, as access is a bit restricted. There's nothing that hot on the intake side that would ignite the fuel, but having said that a spark from a loose earthing point could ignite it.
https://www.sau.com.au/forums/topic/42268-teething-problems/#findComment-864457
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
