Hey guys I want to gather some knowledge about putting and R33(rb25det) engine into my R32 gtst .
Would the 32 stock gear box run fine with the 33 engine , what would I have to look into or change along with the engine ? Would it be worth the conversion ?
Any info, tips or help would be Much appreciated :)
Regards , Michael
https://www.sau.com.au/forums/topic/422827-r32-with-r33-engine/
Actually the forum is for accumulating relevant information to help everyone. It's useless having 300 different threads all about the same thing, forcing people to read too far and wide for one thing and forcing others to answer the same questions over and over.
If we keep everything in one thread we can make it easy to find information and most people will probably find that their questions are already answered.
Such as:
http://www.skylinesaustralia.com/forums/topic/83872-r33-gbox-in-r32/?hl=%2Brb25+%2Br32+%2Bconversion#entry1518749
http://www.skylinesaustralia.com/forums/topic/397751-r32-rb20det-to-r33-rb25det/?hl=%2Brb25+%2Br32+%2Bconversion
I've got a stock Rb25det with a stock RB20det gearbox.
FMIC, exhaust, pod, 10psi boost, good clutch.
no broken box yet... but I'm not out thrashing the crap out of it.
I reckon that a stock turbo'd RB25det will not break an RB20 box.
with my conversion we used a Stock RB25det ecu which required some wiring work.
there is some work required with the heater hoses at the back of the engine and fire wall area.
Other than that it's all smooth torquey sailing.
Should clarify I wasn't recommending doing it ^ The 20 box is sloppy as all hell, I hate them.
But considering you can't really sell them off for much, I'd say it's more worthwhile to run them into the ground behind the 25 and THEN switch to the 25 box.
For the record the RB20 box is no different to the CA18, SR20, RB30ET etc..
There are plenty of people out there with big power SR's who run the stock box, they aren't tooth picks waiting to snap.. Just need to treat it right.
For myself I will probably look for a billet gearset when the time comes as the money on a second hand RB25 box conversion rivals the cost... And I would much rather have a rebuilt billet box than an old sloppy RB25 box.
Wow 6k I would rather buy a 32 GTR , yeah everything box engine bla bla , I seen a 33 engine close to my area a while back for $1300 , don't know if it includes everything ...
When I am shopping Around for engines what do I have to make sure it comes with , so I don't have any stuff arounds
well it depends on your aspects but you would want a complete Rb25
RB25 (series 1 or 2) 2 has vct! ensure it comes with manifold, wiring loom and ecu. that will get you out of trouble. While its out change heater hoses and put in a new rear main seal and things like that to save you the trouble later when its running.
the rest of the cost will come from things like wiring under the dash as its slightly different etc....if you are not running with a gear box change you could prob pull it in for 3k or so
Mine cost $3500 limp in, skid out.
That was, stock series 1 RB25det, new radiator and hoses, stock series 1 RB25DET ECU, new oil/filter/coolant/spark plugs.
We re-used my good coil packs
Engine was $1500 to buy from a wrecker with 3 months warranty.
ECU was $200
Radiator and hoses was about $200
oil/filter/coolant/plugs was say another $100
So about $1500 for a workshop do do it all.
If you're in Brisbane you can have a drive.
The place where you start burning money in this sort of thing is where you're making decisions on what you are happy to live with after the conversion. Things like - do I want to keep the 20 year old air-con compressor, or do I want to put the new one that came with the engine? If the hoses are different (and they are between RB20 and Neo) then a few hundred goes west right there. Same with power steering.
And the same with the things that people like to freshen up. Water pumps, timing belts, oil seals, water hoses, etc etc. They all add up.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
