First up, not sure if this belongs in this section, so bare with me.
i got a 95 R33 manual turbo rah rah rah,
bone stock engine wise and body, just has some coilovers and swaybars, braces etc.
Im having issues with the Battery going flat after 2 days of no use.
Ive replaced the battery, battery leads and terminals,
disconnected the stereo, disconnected the key hole light around ignition as it would stay on when door closed and locked.
boot light disconnect as ive read they can go faulty. removed the turbo timer as the screen shit itself and stopped working (was working great intill electrical gremlins came in)
i had to removed a lot of unused wiring from a car pc install, was wires taped into the cluster, and fuse box, random shit here and there.
from what i gather now its all bone stock wiring wise minus the alarm and boost gauge.
just seems everything electrical is playing up, is it normal for all the dash lights, and clock and stereo to Dim when light puts on?
I havnt tested the alternator to see if its charging, but i put a brand new fresh charged battery in and it was flat in 2 days.
Any idea's on what to check, how to do it would be great, worse case is ill drop it off at a auto electrician, but would rather try fix it myself if possible.
Thanks
https://www.sau.com.au/forums/topic/422902-r33-electrical-gremlims/
test your alternator my man. can do nothing until this is done.
Still doesnt explain why i freshly charged brand new battery went flat after 2 days of no driving. i literally put it in, turned key, it fired up. i shut it down and left it.
2 days later, wouldnt crank, just couple starter clicks. stereo worked for a second or 2 and then wouldnt turn back on. connect jump pack and it fires up like its a fresh battery,
i had the same problem years ago, it turned out to be a faulty relay staying energised even when key was out of the ignition = flat battery, id be checking this or any thing else related (as well testing alternator while your at it)
Have read something to do with the ECU relays, ECU stays grounded or something and thinks its still on. so flattens battery.
I have bought a Multi meter, so will check battery and Alternator ASAP.
Battery tests at 12.65V fully charged
When engine running its 14.22V,
Drops to 9.57V on crank then bumps up to 14.22.
With lights on, AC on, stereo on, and anything else i can put on, and sitting at 2000rpm its 14.17V
after car is off, battery reads 12.57v
test for battery drain it was fluctuating at 0.05 to 0.07 and every 10 seconds or so it would bash up to 7.00, this is testing on a 20amp setting on multimeter with the multimeter between earth cable and earth terminal on battery.
Disconnected the 4 fuses for the Alarm, it sat at a steady 0.03,
Removing the what i believe is the power window fuse from under bonnet it drops to 0.01-0.02
Removing the fuse labeled "electrics" going buy a engine translated picture it drops to 0.00 which im assuming is no battery drain what so ever.
If anyone can shed some light on this, then great stuff
yeah thats what causes most of the drain Mate, 2 posts up i said i removed the 4 fuses for the alarm, guess i should have put its a immobiliser as well haha.
My other R33 reads 0.03 drain and it never goes flat, even after no start in 2 weeks. so in theory the 0.01 from this 33 should mean it shouldnt go flat.... "shouldnt"
Odd thing is i had removed the fuses to alarm/imm over the weekend and it was still flat.. hmm.
Edited by DAN-33
Sorry mate, didn't see that post re: the immobiliser. I never really got a "fix" for the immobiliser problem (just assumed it was a power hungry immobiliser) so I just had it on a smart-charger for most of the time (rarely drove the car in the end prior to selling. Maybe a couple of times a month?).
STILL CANT BELIEVE YOU SOLD IT........
trace all wires back from the alarm mate. disconnect and tag them so you know what goes where. leave it as usual and see if battery discharges. only way to do it really.
also id check the size of your battery. i have some funky jap spec pager alarm on mine and have never had this issue....
yeah alarm is all disconnected and has no power to it, im hoping anyway.
Battery is new, 330cca, unsure of the other numbers though, bigger then the previous battery i know that much.
Im guessing the alarm spikes every few minutes when connected and slowly drains battery, as starter just clicks after 2 days
Yeah, I know. Miss that car heaps :( apparently the new owner blew the head gasket, which is unfortunate. Hoepfully it gives him the chance to build it bigger and stronger.
Bit of a band-aid solution but maybe jsut keep her hooked up to a trickle charger until you can get the alarm/immobiliser checked out. The chargers are about $70 or so from Ricebarn so def. a good investment in my eyes :cheers:
Replaced the alarm module with a new one, same brand so plug and play.
seemed good for a week. Battery was flat again this morning.
Getting a 0.02 that flutters to 0.03 and 0.04 reading on multimeter for the battery draw.
Should that number be solid? and not flutter?
Im about ready to drop it off at a auto electrician, its near doing my head in.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
