R33 Parts CLEAR OUT
Overflow bottle $20
Stock carbon canister $20
R32/R33 NA K-Frame $50
Rear wiper motor $50
Front wipers $20
Stock Side Mount Intercooler $70
S2 Heater Airflow Direction Mode Actuator $70
R33 Stock Suspension arms:
- Front L/R Upper Camber Arms $40 a pair
- Front L/R Toe Arms $ 40 a pair
- Rear L/R Camber Arms $40 a pair
- Rear L/R Traction Arms $40 a pair
- Rear L/R Lower sub-frame support brackets $20 a pair
Battery tray includes bracket, fuse box $50
Steering column surround $20
S2 White Driver Side Door $80 (excludes side mirror, lock, door trim)
S2 Climate Control Unit $50
S2 Dash fascia inc. switches/vents $100
Skyline Door Scuff Kick Plates $20 a pair
Dome Lights (Front / Rear) $30 a pair
S2 Roof Handles $20 set
Sway bar front / rear $20 each
Dash Cluster plastic surround $10
S14 Airbag Steering Wheel $50
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
A pillar trims $40 a pair
B pillar trims $40 a pair
Interior loom (uncut) $50
ABS pump / unit $50
ABS ECU / Skid Module (boot) $50
Bonnet latch $20
Bonnet release inc. cable $20
Boot latch $20
2 x R33 GTS-T Stock Fuel Pumps $50 each
Stock fuel pump cradle $40
  • 3 weeks later...
  • Replies 140
Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
S2 RB25DET Auto ECU - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
S2 40th Anniversary Full Interior inc. Front Seats, Rear Seats, Door trims (front/rear) - SOLD
Front KYB New SR Special Shocks / Rear Koni Sport Shocks inc. Tein S.tech Springs - SOLD
Front wiper motor - SOLD
S2 M-Spec Side Skirts - SOLD
S2 8 Pin Driver side window switch & surround - SOLD
S2 Automatic Cluster 112,649 kms - SOLD
Driver Side Mirror - SOLD
Passenger Side Mirror - SOLD
A/C Fan - SOLD
Radiator Top / Bottom Mounts - SOLD
S2 Bonnet (Damaged) - SOLD
S2 Headlights (Damaged) - SOLD
Lower Fuse dash trim - SOLD
Boot Trim - SOLD
Automatic gear surround inc. Ashtray - SOLD
L/H Tail light inc. cover - SOLD
R33 Complete Lock Set (Includes boot, glovebox, Steering Column inc. ignition barrel, Driver / Passenger Lock, S2 Factory Key) - SOLD
Rear vision mirror - SOLD
Automatic Tailshaft - SOLD
R33 S2 Automatic Gearbox 112,649kms - SOLD
Fuse Box Loom - SOLD
Automatic Transmission ECU - SOLD
S2 Indicator Stalk / Light Stalk - SOLD
Exhaust Shield - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
RB25DE S1 VCT, 115,xxx kms inc. Engine loom, ECU, AFM - SOLD
Passenger Rear Pod (white) - SOLD
2.5" GTS-T Pipe to 4" Varex Tip Exhaust - SOLD
Sun Visors - SOLD
RB25 Clutch Fan - SOLD
Brake Booster Master Cylinder BM44 ABS - SOLD
  • 4 weeks later...
Still have the parts listed below few others that are not listed.
Overflow bottle $20
S2 A/C Compressor $50
S2 A/C lines $10
S1 A/C lines $10
Front wipers $20
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
Boot latch $20
2x Stock Fuel Pumps $40 each
Factory Fuel Pump Cradle $40
  • 1 month later...
Available:
Exedy OE Clutch (NSD098U) $20
Overflow bottle $20
S2 A/C lines $10
S1 A/C lines $10
Front wipers $20
S2 Heater Airflow Direction Mode Actuator $70 (gets rid of clicking/clunking noise behind dash)
S14 Airbag Steering Wheel $50 (Fits R33 GTS/GTST)
S2 Dashboard $70
Interior Carpet $20
Aircon core $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Interior loom (uncut) - SOLD
Boot latch - SOLD
Driver Side Window Regulator - SOLD
Stock Side Mount Intercooler - SOLD
  • 3 months later...
below parts are still available must clear out the garage, make an offer
Located: Melbourne (SE Suburbs)
R33 GTS (Coupe) M-Sport Side Skirts $100
S2 Automatic Shifter
Driver Side Door (White) Shell $50
SRS Airbag Module $50
Passenger side SRS airbag $50
S2 A/C lines $10
S1 A/C lines $10
Front wipers (white) $20
S14 S1 Airbag Steering Wheel $50 (Fits R33 GTS/GTST)
S2 Dashboard $70
Interior Carpet $20
Heater evap unit $20
Heater fan $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
2x Stock Fuel Pumps inc. cradle $50 each
  • 5 weeks later...
Available:
R33 GTS (Coupe) M-Sport Side Skirts (Midnight Purple) $100
R33 NA pod enclosure $50
Blitz SUS Power Core Type LM Pod Filter (plastic top slightly damaged does not affect performance) $40
R33 Automatic shifter inc. cable $40
S2 A/C Evaporator Assembly $20
S2 Blower Motor $20
S2 A/C lines $10
S1 A/C lines $10
S2 Dashboard $70
Interior Carpet $20
Roof lining $40
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Boot latch - SOLD
Driver Side Door (White) Shell - SOLD
  • 4 months later...
R33 Parts left need them all gone asap make an offer.
370cc (x6) side feed injectors $80
RB25DET S2 AFM (Pink Label) $70
R33 NA Pod Filter enclosure (Hi Octane) $50
Stock Rubber Intake $20
Blitz SUS Power Core Type LM Pod Filter inc. Adaptor $20
S2 Blower Motor $50
S1 A/C lines $10
S2 Dashboard $50
Interior Carpet $20
Roof lining $20
A pillar trims $20 a pair
ABS pump / unit $50
Bonnet latch $20
2x Stock Fuel Pumps $20 each
R33 S2 Dashboard $50
S2 Blower Motor $50
S1 A/C lines $10
Interior Carpet $20
Roof lining $20
ABS pump / unit $50
Bonnet latch $20
SOLD:
Heater Core - SOLD
Front Guards - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
A/C Fan - SOLD
Boot Trim - SOLD
Front Pipe - SOLD
Dump Pipe - SOLD
HICAS ECU - SOLD
Sun Visors - SOLD
Boot latch - SOLD
S2 Climate Control Unit - SOLD
R33 NA Pod Filter enclosure (Hi Octane) - SOLD
S2 A/C Compressor - SOLD
U got the water temp ecu sensor? If so how much.
I know slit of Nissan use the same just lazy to go to local wrecking yard :)
Sorry champ don't have that part :)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
