so I have an R33, non turbo auto, sedan, I've only had it for a few days and today on the way to the rego place and back it cut out randomly three times while I was driving.
The first time it cut out while I was turning into the car park, I stopped, turned the key to off and straight away turned it on again and it was fine to park.
The second time I was driving at about 80km up a hill, it cut out for a bit, then fired up again, then a couple of seconds later it cut again and I had to pull over.
I tried to start it again but it wouldn't fire and idle. I went and tested the battery with my multimeter and it was showing 12.8 volts so as wasn't thinking it was an electrical issue.
Hopped back in the car and it started up straight away and I took off until about 500m from house where it cut out a third time, same sequence as the second except the road I was on is fairly flat.
Before I tried to start it again but it wouldn't fire... now I'm here hoping someone can give me some suggestions. I am new to R33s and Skylines in general. Any help would be appreciated.
https://www.sau.com.au/forums/topic/423176-r33-cutting-out-while-driving/
Sounds like your Crank Angle Sensor is on it's last legs.
Do a search for "CAS" or "Crank Angle Sensor" and see if anything sounds familiar.
Brings back memories of my old Bluebird.
search on here or just in google?
I've looked at a few other threads and I think it might have something to do with the battery, alternator, spark plugs (even though apparently mine were replaced before I bought the car),
coil pack, AFM, O2 sensor or as you said the CAS. Is there anyway I'd know, or a process of elimination I should follow?
Search on here in General maintenance, Naturally Aspirated Performance and forced induction etc...
Start at the cheapest options and work up.
Check battery connection, check all electrical connections. including coils etc.
While you're doing that, buy $30 worth of new sparkplugs and replace them as "apparently" is not for sure. (although your problem is unlikely caused by sparkies.)
Same as coil packs as all 6 coils or sparkies would have to crap out at the same time. (do non turbos have individual coils?)
Is it series 1 or 2? Series 1 have an ignitor module that controls the coils. (The modules do die also)
Clean your AFM (with proper Airflow Meter Cleaner) and connector there too.
If it dies at approx the same distance from home a few times and only when warm, (not cold) it does sound like CAS.
(If any of this is noobish misinformation, then I will stand corrected, but none of it will hurt to try.)
Good luck.
4DOOR LoVe !!!
Ok so this morning I checked the spark plugs... they did look pretty new and didn't look like they needed changing. I tried starting the car and nothing happened when I turned the key.
Multimeter showed 8.1v. Went to the local mechanic and got him to test two of my available batteries. Both had dropped cells, therefore useless. I bought a brand new 600cca battery.
Then I went for a drive to see if it would still cut out. Drove it with overdrive off so it could rev higher to get it hot faster. It drove for ages (approximately about 30-45mins) until it cut out, wouldn't start straight away,
waited about 30 seconds and it started up fine, maybe about 100m it cut out again, 30 seconds later I was driving off. After that it was trying to cut out once or twice but I kept pumping the accelerator and the 33 kept going.
20km it cut again.
This all seemed to happen when it was warm/normal temperature.
Also for as long as I've had it, the idle isn't as smooth as could be.
Before I bought it had been sitting for a couple of months, hence the battery situation. Also the fuel may have been sitting for that length of time as well (now filled with fresh premium 98). Not sure if that may have anything to do with it.
Everything seems to be pointing towards the CAS as all faulty symptoms I've looked up relate to what I'm experiencing.
Now is replacing or checking the CAS something I can do even though I have the same skill as a first year mechanic just starting out? or would it be worth just taking it down to the local mechanic and getting them to do all their tests?
  • 4 weeks later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
