Hey all, I'm from lakes entrance, the lower part of Vic, which is about 4 hours away.
I see every now any then that there are monthly meet ups, but they are during the week, and because me and friends work full time, there's no way we could get down for one, was just wondering if anyone knew if there were any meet ups on the weekends?
https://www.sau.com.au/forums/topic/423283-meet-ups/
Hey mate,
The monthly meet is the 3rd Wednesday of every month (currently located at Garage Cafe, which is just near the city)
For meets on weekends, keep an eye on the Events section
http://www.skylinesaustralia.com/forums/forum/102-events/
or if you're an SAU VIC Paid Member you'll get access to the members section and the Exclusive events area
http://www.skylinesaustralia.com/forums/forum/108-exclusive-events/
https://www.sau.com.au/forums/topic/423283-meet-ups/#findComment-6811440
Hi mate,
There are plenty of events on every weekend, I have a calendar full of them. But I can do you one better, how about we put together a little cruise to Lakes Entrance to come and meet you?
If you want to know what events are on, just shoot me a private message.
  • Like 2
https://www.sau.com.au/forums/topic/423283-meet-ups/#findComment-6811634
So Lakes Entrance it is! The route will probably just be the highway as it's a fairly long drive just to get there from Melbourne.
How about a BBQ lunch or something? The Esplanade Reserve looks like a decent place to stop and have lunch as it has plenty of parking and it's right in the park. I've never been to Lakes Entrance, so Chris do you think that is a good idea?
I'm thinking we do it sometime mid to late May as we have a members only cruise coming up at the end of April as well. If people are cool with those ideas, I'm happy to put it together :)
https://www.sau.com.au/forums/topic/423283-meet-ups/#findComment-6812773
What's the Esplanade Reserve like at midday Sunday? Does it get packed or will there be space for 10-20 cars?
Just checking my calendar now, I think Sunday the 19th or Sunday the 26th would be best as there really isn't much of anything on those dates (yet). I'm leaning more towards the 19th (though it's the same day as the GTCC Interclub Go-Kart Challenge). How is the 19th for you Chris?
https://www.sau.com.au/forums/topic/423283-meet-ups/#findComment-6812794
Well at this stage official SAu Vic cruises only allow SAu Vic members due to public liability insurance not being able to cover non paid members..
But you guys a more than welcome to organize a non Sau Vic official cruise.. Where anyone can come
https://www.sau.com.au/forums/topic/423283-meet-ups/#findComment-6820784
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
