I'm very keen to take mine down there. But as its still in Jetwreck's dad's garage I'm just not sure how it will be running this week. I was thinking about going in a week or 2 and was hoping Jetwreck's would be ready to trek there also. Keen to see the 13 sec line broken
What kp/h did dale hit when he got the 13.8?
100mph or piss fart away I think.
13.8@ 100.11MPH :yes:
I;'d like to but not ready at this stage..what time do you think it would get??
I'd be betting a 13.6, maybe better.
Your car has the same turbo as mine, with a bunch of other supporting mods and a damn good tune. ;)
Theo ran 13.9 with 206rwkw, and yours would have to have at least 30 odd KW more than mine.
What mods are you running again dale? Just trying to work out where my car should be at
Well my car is back together but I need a new BOV. Don't think I can sort that before tomorrow so I'm out for this week sorry guys
It's only farting, it should still drive well.. Just block it off like I mentioned if you are worried.
When's the tune? ;)
It's about time I ran mine, but Calder is closed at the moment. Nearest drags is Heathcote, 3 hours away. I may as well drive up for this.
  • Like 1
When's the tune? ;)
It's bleeding off boost which sucks.
Tune prob not for a while. As much as I want an emanage. I have spent way to much money of late. The bank balance needs to recoup. But is has nismos so it will have to do the job for now.
If I do blank off the bov could it cause any damage?
Maybe a trip up to Sydney and wsid is due for you. I bet we could get a good stag turn out if you were also running. Plus Craig might sort his shit out also.
Edited by Brick
I went back to a stock stall converter, no hope of boost off the line for me, most of you would have me by 3 car lengths at the start while I crawl away.
But I would drop the high stall back in, just to upset Craig, if I was coming up sometime. :)
Blitz dry cotton panel filter, my own 2.5" mandrel bent suction pipe, Sierra S2 Highflow (ceramic coated), stock actuator with 5mm preload, plenum spacer, 3 inch dump (ceramic coated), 3 inch midpipe with 100cpi cat (ceramic coated), Fujitsubo Legalis exhaust and the brake wire cut mod.
Stock airbox, stock intercooler, stock computer, stock injectors, stock fuel pump.
There is other stuff, but not that directly effect performance.
The key mod in my case; is the loose nut behind the steering wheel. :whistling:
How much stall do you get off the line with the high flow Dale?
This is the issue I had; I could only stall the car to 2500 RPM; which left me with 5-7 Psi leaving the line. It got away ok; but nothing like it does on the street. At 2400 RPM it was still registering vacuum on the boost gauge.
I believe Sky^rt had a similar issue at Calder building boost at stall; but even knobbled, he ran a 12.9. :woot:
A full blooded launch would've put him closer to mid 12.
On the street; I can stall it up, it takes around 2 seconds to reach 2500 RPM and once it reaches 5 Psi, it whips up to 3200 RPM and 15 Psi.
Release brake; the torque split gauge goes to it's maximum, it spins the rear wheels pretty hard for about 4 metres, then pisses off.
The difference in launch is MASSIVE.
I firmly believe a "Street Launch" would've had me around 13.6.
Such is life. ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
