S A U - N S W Texikhana - Queen's Birthday Holiday Monday
I'll come to check out this Texi thing, all new to me. Anyone can give me a ride along?
Also that soundtrack in the video makes me cringe.
I'll be there to help out in the morning if you'd like a lift Ricky.
And thanks R-o-B for helping out too :)
Thanks for the offer Terry, but I meant if someone could offer a ride along in their car during Texi to get a feel for it. Unless you'll be taking the N1 for some donuts then I shotgun! ;)
Going to see if I can get leave for this.
Got a plumb back for the gate. And some tyres I need to get rid of. :)
It feels so cruel plumbing back the gate :(
With rego? =-o
Rego would be good! Found a couple of decent S13's which fill the shitbox skidder requirements very well.
The Merc truck might be a bit of fun on the skidpan :P
This i wanna see!
I recken that would make a good SAU "rego trailer" or something ;oD
Sorry - haven't had time with work.
Will try and get something happening on the weekend and will respond to everyone who's entered. More people are always appreciated, there's still spots.
No need to apologise man :) If there is anything i can do to help just send me a PM!
I'm going to do lid skids all day!
Be rude not too!
I'll be helping only on this one.
Do it.
Might try come down in the Stag for this. See how we go :D
Would be good to see a C34 that can do real skids !
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
