What a glorious garage you'll have Chris with Blue 'n White :)
Watchamacallit's recommendation of Iron Chef may not be a bad idea considering the fact that Kristian hires Daniel over in Japan to pre-inspect cars F/S at auction or private treaty. They don't trust the grade system per se.
i`ve been buying cars out of japan for 18years now ..there is nothing not to trust about the grade system ...some auction houses are generous and some are tough but experience tells which these are :yes:
You say there is nothing not to trust about the Grade system?
Having been to Japan since 1975 has taught me sociologically, theologically, culturally and philosophically that the Japanese males abide and live by structure, discipline, ordered roles, yang concepts and ethics passed down by Taoist- style traditions. The Grade system should be a trustworthy structure according to the above; but it isn't!
Cars that appear in Osaka that have come from as far north as Hokkaido has happened before - and will happen again.
I don't doubt your experience; but anyone who trusts the Grade system only can still (without precautionary backups) end up with the rusty car.
JDM_Performance once bought one from Northshore Prestige - with regret from a faulty Grade system.
Aggroman once bought one from Top Secret Imports - again with regret from a faulty Grade system.
Therefore, I say to you that the Grade system isn't the only criterion to abide by!
imported over 200 cars ...2 not what they should have been ...both from same auction house ..rest as described ..bottom line you get what you pay for end of story ..also the 2 cars that were not described accurately had money refunded by my dealer in japan ..same guy 18years
Edited by jake32
...rest my case.
To you Chris, apologies for going off on a tangent!
less than 1% not accurate ..i`ll take the punt ..if you really think that an australian or kiwi car dealer crawling over a car before auction is a big deal than go for it..millions of cars are traded with this system if it was a failure the it wouldn`t be around for the decades it has been.its a system that works if you know what your doing
Sydney Compliance Centre CEO will explain how some N. Honshu cars (even from Hokkaido) have travelled south covertly to be auctioned off down there. This will be done on a Tech Night for SAU Members next month. More than two importers I know, prefer to rely on more than a Grade system ie an inspection!
Back to Chris' thread!
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
