I have been searching on the net and thinking of a far while now but have not found any answers.
Does any one know the differences between a r33 GTR front sub frame and a r33 GTS-4 sub frame
Are there any differences Are they the same. Has any one had them side by side.
Does the GTR have the same chassis as the GTS4 or is the GTS4 the same as the GTST
or are all 3 (GTR, GTS4 and the GTST) all different in subframe and chassis specs
Any info would be very helpfull.
I do know the GTR and GTST are different but unsure about the GTS4 and GTST.
https://www.sau.com.au/forums/topic/424291-r33-gtr-and-r33-gts-4/
If you are talking front subframe then based on a 32gts4 they should be the same. I have a GTR sourced one under mine currently.
My understanding is body differences and minor track differences.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
