VG30 BallBearing Turbo complete with actuator, direct bolt up option for RB20/25, , Exhaust Turbine snout has been highflowed from 42mm-52mm.Comes with original twin blade comp wheel. All that needs to be done is have a TO4 Comp wheel installed and this turbo is capable of 200rwkw+. $450 for more info PM me please. cheers
https://www.sau.com.au/forums/topic/42436-vg30-turbo/
Guys this an unfinished project of mine, I didnt put the TO4 comp wheel on cause i have decided to sell my car. My intentions was to do the same mods that BOOSTED has done the only stage i got up to was machining the exhaust snout from 42mm to 52mm. Not sure how it would work on an RB20 but i know that BOOSTED has gotten upto 266rwkw
https://www.sau.com.au/forums/topic/42436-vg30-turbo/#findComment-889275
The non ball bearing vg30 turbos came with a steel exhaust turbine so i have been told. The VG30 Ball bearing came with a ceramic. With the mods that have been done to this turbo you dont need to run high boost to achieve good power. BOOSTED ran his @.9bar and got 266rwkw
https://www.sau.com.au/forums/topic/42436-vg30-turbo/#findComment-894679
Correct. This turbo has a ceramic wheel which results in sledge hammer style boost build. This turbo will not run more than 16-17psi boost due to the trim on the turbine. Due to the larger compressor wheel, the turbo spins at 90,000rpm instead of 121,000(t3) @ 15psi. Ceramic turbine failure is very very unlikely. Even at 17psi rpm is only 96,000.
I have constantley made 250+rwkw on 4 different dyno's on 14-17psi.
if you can't afford tyres DO NOT BUY tHIS TURBO- I was getting wheel spin on acceleration in 4th with 18" 275's. Good turbo for drift.....not very good for the hills as boost hits way to hard.
RB25 would expect FULL boost by 4100rpm
RB20 would be slighly later
https://www.sau.com.au/forums/topic/42436-vg30-turbo/#findComment-894772
Boosted sold me a steel wheel version quite a few
months ago. Will finally be putting it on after auto
salon.
MADGT4 i also have a 32 gts-4 so i will advise as soon
as it is installed and running. Most people are saying
i should make around 200 rwkw with 1 bar of boost.
https://www.sau.com.au/forums/topic/42436-vg30-turbo/#findComment-906140
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
