It sure does. Easy and great for skids or 2wd dynos.
BTW you don't need a controller to do that. You can also:
Pull the 4wd fuse out (near driver's knee)
Turn the car off, then on, while it is moving (slowly! be careful!)
https://www.sau.com.au/forums/topic/424362-32-gtr-in-rwd/#findComment-6831946
Oh ok excellent. Im looking at a track car right now and was tossing up between a gtst or gtr beacuse I could do more events in the gtst.
But if its safe to run the gtr in rear wheel mode then that's the one ill get
https://www.sau.com.au/forums/topic/424362-32-gtr-in-rwd/#findComment-6831988
