hey all got few things to get rid of;
*Nokia 3315 (6months old, brand new battery today, original case)- $50
*Flashpoint Alarm (got a new mongoose as a present, no need for this works fine) $749 brand new, 6 months old- $350ono
*NOW selling my kenwood headunit KDC-6020 pm for details and pics- $220+post- SOLD!
*NOW selling my standard r33 gts-t headunit- $30+post
*NOW selling my TYPE M rear bar- $200+post
side skirts $150+post---SOLD!
rear spoiler-$140+post---SOLD
- 2001 mitsubishi magna vrx rear bar, slight dent but no cracks etc-$offers
- r33 gtst stock cooler with pipes, brakets etc-$90
- r33 gtst stock bov- $25
- r33 gtst stock springs- $25
- r33 gtst stock front, dump pipes with heatshields and 5" tip- $30
- ralliart hand brake lever for lancer- $10
DD prefered with postage at buyers expense if cannot be picked up
pics will be up shortly so email if u wana see the stuff...
alot of stock parts goin out the door so if theres anything u need thats not there let me know coz they could be goin pretty soon...
cheers...ben :D
https://www.sau.com.au/forums/topic/42442-parts-4sale/
  • Replies 50
the side skirts are black not the slightest bit of damage, id have to get back to u shortly to see how much i will have them for once im ready to let them go, if u dont need them in a hurry i can let u know as soon as im gonna let them go, whats ur email so i can put it down?
cheers...ben.
https://www.sau.com.au/forums/topic/42442-parts-4sale/#findComment-867325
Hey dude,
Does the cooler come with all the pipes from the cooler to the turbo and the cooler to the crossover pipe?and all nuts and bolts to attach it back onto the car? how much to ship it to brisbane?
Also after the turbo heat shield if you have one.
cheers mate
https://www.sau.com.au/forums/topic/42442-parts-4sale/#findComment-867582
Greg: check pm...
voityR33: it comes with all the nuts and bolts and brakets etc to bolt onto the car, also comes with all the pipes except for the pipe that comes off the turbo, but has all the other ones...i can get pics for u tomorrow of all the parts that it comes with so u can see if all the parts needed are there jus leave us ur email...
cheers...ben.
https://www.sau.com.au/forums/topic/42442-parts-4sale/#findComment-867901
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
