Hi all,
As much as I really like the leather on my new V, I'm looking at getting seat covers to protect the leather. I use the car daily and I'd rather have a cover than risk ruining the seats.
To that end, does anyone know if the 350z seats are the same as the V? Ive found some places that can do custom covers for the z, but none for he v. Or does anyone know someone who stocks/can make the covers?
I'm not looking for leather retrim or anything like that.
Cheers
https://www.sau.com.au/forums/topic/424447-seat-covers/
I have been looking for some for the sedan. but haven't had much luck.
There are some leather type covers that pop up on ebay every now and then, but they want about $500 just for the fronts or rears, which is far more than I intend to spend.
When I get around to it, i will have a look around on USA suppliers. G35 covers should be mostly the same..
https://www.sau.com.au/forums/topic/424447-seat-covers/#findComment-6833572
I think having covers over leather will not stop them from being damaged - you will probably prevent scratches and scuffs but the cover will still slide around, and may possibly stain, if not good quality
Main thing with leather is keeping it clean and treated regularly. Also avoiding bad habits such as sliding your butt (or back) over stitched edges and wearing pants with sharp studs or zippers etc
Edited by junkie
https://www.sau.com.au/forums/topic/424447-seat-covers/#findComment-6834202
Is this to keep the leather nice for the next owner? Seems a shame to cover it up...
Just been really curious about the whole seat covers thing since I arrived in AUS 12 years ago... In the UK generally you only have them to "upgrade" a plastic seat or when you have unmentionalble stains you want to cover up..
https://www.sau.com.au/forums/topic/424447-seat-covers/#findComment-6834566
I think its more a case of having something nice and keeping it nice while its in your possession, not so much thinking about the next owner
Personally I hate ruining anything with careless use and don't like having broken or damaged stuff that I worked hard for. Getting more cash when it comes to sale time is only a bonus
https://www.sau.com.au/forums/topic/424447-seat-covers/#findComment-6834703
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
