Hi guys,
So as some of you may know I've been doing bits and pieces on my car while I recover from a brain tumor. Anyway I installed -5 turbos all new gaskets and what turned out to be a shit split dump pipe, so I did that all with the engine out of car all new gaskets studs etc. it now has adaptronic ecu that jez will tune but I wanted to run it at idle to leak check before I trailer it up there. So the first time it took a few days to get it to idle and found two copper washers leaked which were new, fixed that and noticed exhaust leak from split pipes where I didn't put the bolt the retains the separation plate for stock turbos, so I installed a bolt while I had the twin turbo pipe off and was listening for another exhaust leak which I believe to be from the split dump flange itself. So I had to muck around a bit to get to to idle for a while less than 10 mins when I noticed steam due to the fact the water lines were off while I was fixing these pissy leaks. Long story short there was oil sprayed from where the twin turbo pipe attaches on both turbos so I don't really know the history of them but they are supposed to be 2000ks old which they do look like, anyway have I cooked the seals? Is it normal for some oil? Or the other thing is pressure reducer I rang gcg twice and they said I did t need one but regardless my banjo is marked j which is supposed to be r34 stock reducer? Any thoughts guy? Btw I comp tested engine and its all around 160psi each cylinder on forged engine with cams etc and I am going to buy proper dumps and piss those shit split pipes off even though they were Aussie made :-( it never went over 2k rpm and don't forget the brain tumor lol.
Scott
https://www.sau.com.au/forums/topic/424632-5-install-problem/
  • Replies 40
Its hard to understand what you're written. I'll try to state the key info - let me know if this is correct.
- second hand -5 turbos fitted to rb26
- coolant lines not connected
- oil lines and drains connected
- engine run for 10 minutes
- oil spraying out both compressor outlets
Its not possible that you cooked the seals without the water connected. Even Garrett says the water cooling is optional, and you put sweet f**k all worth of heat through them just idling.
Unless theres an issue with your oil drains backing up I am 100% certain you were sold duds.
Yep there's a good chance they were buggered I guess I wondered why he took them off so early but they did look new in every way and span when and could hear them spoiling down even from idle but no they are like bush bearing they spin but not like they used to.
Scott
Scott
Since the way they spin has changed, I'd be worried that perhaps there were ok when you put them on, but have since been damaged somehow. And given that, i'd be worried about putting on a new set and damaging them as well. GTScotT has said that the coolant is not critical, so it sounds like there's some other issue with the installation. I would be checking the oil delivery to the turbos to verify its at a sensible flowrate and pressure. CRD did this on my motor after it lunched a highflow, which they replaced with -7s.
It's standard oil and water lines which were clear and functioning as it was spitting oil out so it was coming from feed lines, I have installed 3 sets of non bb turbos on a few 26's before the only variable would be a restrictor which most say is not required but maybe oil pressure pushed the seal out to cause the problem or they were faulty in some way before as they were 2 nd hand but were only run at just above idle I guess I'm lucky they didn't fail on the dyno
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
