Congrats Chinny!!! You'll love it :cheers:
Maybe I will paint mine pink - nah, just kidding, there are about 8 black ones that I know of and see around the traps, not all members here though.
there is one less black gtt on the roads, see other thread in vic section.
I see a black gtt with gold wheels parked opposite rmit swanston st quite regularly, no other noticable mods though.
  • Replies 42
hahah :D Never seen the black one at RMIT, altho, i'm not there a lot :)
Use to see a black one parked on Beach rd, just a little bit down from 'The Stokehouse' a fair bit. Use to have gold rims, but now has black P1? Buddy club rims. Haven't seen it for a while tho...
So you bog the holes up, then paint over them? Wouldn't that mean the whole qtr panel needs to be sprayed cos you could tell where you painted? Know anyone who could bog it up for me?
guess i should go update my profile! :D yay! lifes little pleasures...
one other thing, do both the rear afterburners light up when you have your front lights on? Or is one only for braking?
cheers
Adz - I was watching the "making of" DVD for GT4 last night and the R34 they have in that has only the large outter lights are coming on under braking so whom ever told me that this was changed under complience was full of :bs!:
only in the 32's are the lights snipped during compliance. the 34 only has one pair lit, there's no snipping involved. 34 and 33 lights are left as is. The only reason 32's are snipped is so that they comply with the production 100 or so taht was sold here.
Guest RedLineGTR
i've seen more than 5 r33's with the lights snipped on the road and i doubt two globes have gone at the same time....also some videos i have seen from jap and the uk the r34 gtr's...some have both lights comming on and some dont..this is without the headlights on :) so dunno what the story is :)
those holes should be easy to fix up with bog.
as for the colours, the original nissan colours were made by dupont, so using the dupont colour composition codes I should theoretically be able to get an authorised reseller of dupont paints to mix up the correct batch innit? only prblem is it dosen't give me concentrations etc, so if they thinned out one layer etc you wouldn't know until you tried it on the car hey?
Ummm sorry munkey but i wouldnt be putting bog in it....i would be welding the holes and in regards to the colours if i had a new car and got it mixed it wouldnt be right,and we havent even talked about sunfade,previous repairs ect on the used cars that we all drive.Also the factory paint is High bake paint,a diffrent system all together,its not available anywhere and if you got it you wouldnt be able to use it properly....
Would it be hard to make all 4 lights come on when braking, AND when you don't have your parkers/lights on? Hard to wire that up?
its an easy mod to do....just fit a double fillement globe and socket to the tail lamp
oh kool, so many things to do ONCE the car is regoed! :)
if you welded the holes up troy, would u then have to strip back/respray the entire quarter panel? they are definitely going to be filled up somehow. Do you think it would stuff up compliance if i got it fixed before vehicle inspection and put a stock spoiler back on? The stock rear spoiler wouldn't be a problem, but i'm not sure if a little fix up like repair the holes would be...
i'm guessing this is a fairly expensive process to fix what's left behind from the rear wing?
cheers
Troy do u think that kit is going to be a problem for compliance? It's a factory kit, but i've just been talking to Dean over at www.upimports.com.au and he said i could have a lot of trouble with it??
you have any thoughts bout it? It definitely is a Nissan kit, just not made by them, but came from the factory like that.
that's what i was saying to Dean, but i was missing the point. That being, doesn't really matter if it's factory, cos the original car the was crashed and engineered (the first R34) was most prob bog stock. Meaning there is no engineering evidence for the kit on the car. Dean was saying things like the rear wing being a hindrance to... f*ck it, i'll just paste in what he said. He explained it really well.
first post:
hi,
that kit will not pass compliance, i doubt anyone will do the required engineering for a kit, if its factory fitted by nissan its a possibility, but for a kit that is supplied to a car as an accessory will not pass.
there are specific guide lines as to how a car should appear and bodykits factory fitted or otherwise will not be allowed, if it was a normal compliance car, its possible to do, but as a sample car that inspectors are going to crawl over, they will pick it and it will become a discussion item that u will have to prove is factory fitted and does meet all the adr requirements, which u wont be able to do.
there are a number of reasons why a kit wont pass and just a few would be.
rear spoiler will impede the view through the rear window, front spoiler may affect air bag deployment and side skirts will change the height of the vehicle from the road, all these specs have to be supplied with the engineers reports.
stereo systems dont affect adrs.
second post:
your missing the point, when an engineer does all the testing for a particular vehicle, it is generally a bog stock car.
if your car is not identical to the engineered vehicle, it simply wont pass.
everything on a r34 that does not meet adrs has to be modified to meet adrs, the spoiler etc wont have engineering evidence and without it, it wont comply.
put simply there are 2 sample vehicles, the first one the engineer does all the testing on and then your car, your car must be identical in virtually every way to the original engineers test car.
oh kool, so many things to do ONCE the car is regoed! ;)
cheers
Theres a few ways of going about it,if it was mine i would weld the holes,tap it up nice,file it and blend the colour into the 1/4 panels and clear the two 1/4 panels,roof and the A pillars that way it would look untouched.you could blend the paint out through the roof somewhere but being black it would look milky in the
blend out area.I could do it to a car and you wouldnt notice but i couldnt do it to someones car coz i would notice!!!!!
heheh, i'm sure i couldn't tell even if i had the hubble telescope, knowing the work that you do. ;)
did u read my post about the kit being a problem for compliance? i'd like to know what you think about that. I thought it would be ok, like shan, cos it was factory. But apparently it's more dependant on engineering evidence, rather than whether it's factory or not.
we'll just have to make you forget you did it troy.
dean does have a point about your car being the sample car. if it was a car that was goin for a regular compliance it would be OK, but I just realised that you were gettin a compliance as part of some raws approval or something aren't you? They might be more stringent. Either way, it dosen't hurt to give it to em like that. I'll give you my original of the catalogue as well, in case you need to prove to em it came from factory like that. If the compliance centre dosen't wanna risk it they'll return your car to stock before the engineer scrutineers it.
Basically your job is to get them a car, they'll sort out the rest, which is why you're gettin it for free, coz at the end of the day, it IS a major hassle.
#1 The wing is poo and reeks hardcore
#2 I cant see a hassle with the front bar because it has the original indicators in it doesnt it?If any body say any crap about the airbag its depleted by the sensor in the centre of the console not by any thing else however i am under the understanding that the vehicle has to be identical to any of the other vehicles that will be done under this RAW so i would assume that they would want a standard vehicle...the height may be an issue and as you been told its not what you say or prove with brochure ect to DOTARSEHOLE its what the evidence pakage says.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
