  • Replies 70
Snowman - we shouldn't laugh at retards in vl's, even though there everywhere on our roads.....
banned_leb - don't you think you're barking up the wrong tree??? We know your immature and looking for trouble, please keep it over there in Altona....
Guest INASNT
must be really hard for u guys huh...
lossing to retards all the time..
:) u make retards look smart
And what exactly are you beating us with??? a car that has to come on a trailer, run slicks, transbrake, sit on the start line for 10 seconds spooling your stupidly large turbo that has a 1000-2000 rpm power band, suspension that you can only drive in a straight line with and a powerglide or other gay auto trans because you are to retarted to drive a car with manual trans, road tyres, and a thing called a clutch that you can drive home after racing and drive to work the next day???
Stop comparing a drag car to a street car retard.
If you only had a clue in life you would be dangerious
one day mate.. and i got CNBLOW to prove it.. im not scare dto walk up to some one..
just lucky it wasnt u . for both our sacks. i didnt feel like being locked up
what you used to the prison showers or something lol... :jk:
Guest INASNT
alrite man, your all hard now cause you drive skylines and need to post pictures bagging vls cause u cant beat em.  sell your shitboxes and get vls cause thats the only way u will run sik times.
do you actually still think any of us actually car about beating a shit box vl at the drags who has to run slick, auto box and transbrake and go home on a trailer???
If you do you are more retarted that i first thought!!!!
ROFL! What a slug! Id be embarresed :)
What kind of 60 foot times?
Yeah I guess it is an embarrasing time considering a few vl's were running 10's and 9's, but fortunately I'm not willing to drive around a boat that's got a NISSAN motor in it..... maybe with slicks, a shit load of boost and 2 speed powerglide, I might get into the 10's aswell......
60 foot times were in the 1.9s
I just got off the phone with acsplit, Ryan took his 31 Ti to Calder and I just got confirmation that he ran a 11.94 on street tyres!
FWOAR!!!!!!!!!!!!!!!! :headspin:
Congrats to Ryan and crew, and we'll be seeing you on FullBoost! :D
15" 205 shitty old bridgstone G grid tyres and boost set @ a safe 15psi full street trim :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
