He could even do up a little sau qld logo in the corner.... Hmm would just need some blank backing plates/badges. I just sent a few emails to stores in toowoomba that I think might carry them :)
#gettingshitdone
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
