He could even do up a little sau qld logo in the corner.... Hmm would just need some blank backing plates/badges. I just sent a few emails to stores in toowoomba that I think might carry them :)
#gettingshitdone
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
