Today was a spectacular day! A big thanks to everyone who attended. It was good to see you all enjoying yourselves and that there was no major carnage. The way you all conducted yourselves today is the reason why SAuQLD is always welcome to Willowbank and QR.
Even though I wasn't running, it was still good fun spectating and fueling the banter!
Big thanks goes to Todd for arranging the day and for Boz sorting the payments and ticketing out.
Now onto the Photos!!
  • Like 1
Thanks all for the day. I had a blast out there.
I ended up getting 12 runs in with a best of 13.739.
And how could I forget- a very big thank you to the organisers!!!
Edited by sneki81
  • Like 1
agreed, awesome day was awesome. Lots of runs, I have 10 slips but im sure I did more runs than that.
Best of the day for me was a 13.857 :) a big improvement on last years 14.4..
The weather really did shine on us today. I talked to everyone up home way this arvo and they said it was wet and rainy almost all day.
Show us your slips!
  • Like 1
Awesome day, cheers for organising it. First run consisted of a 16.1 something with final run of the day resulting in a 15.020 :) needless to say I'm pleased with this
  • Like 1
Show us your slips!
13.728 ;)
Well get the slip tomorrow
So yeah, just finished editing a little 3:30 video of todays exploits :)
I have learnt two things. 1 - I need better video gear. 2 - I need better sound gear.
GoPro's are great at being strapped to things cameras otherwise wouldn't be strapped to and TERRIBLE for everything else.
Probably another 15 minutes to compile and compress, then god knows how long to upload it.
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
