hey all...
just wondering the stoping distances for skylines...
32's gtst's, gtr's.
33's gtst's, gtr's
and 34's, gtt's and gtr's
im really just wondering about the brakes that they have as i will b looking 4 an upgrade. I know that the 32 gtr has the same brakes as the 33gtst and so the 33 gtr's are obviesly beter. What about the 34's brakes? i have no idea about these...
thx
https://www.sau.com.au/forums/topic/42494-skyline-brake-issues/
If you want to improve your stopping distance a good "brake upgrade" would be better quality tyres :cheers:
If you have poor quality tyres they will just lockup and skid rather than stopping. If you have high performance brakes but low performance tyres they will just lockup and skid.
If you want to do quick heavy braking time after time then a brake upgrade would be needed such as: Fluid, Pads, Braided Lines, Calipers.
no offense 2 anyone and apoligise if offense is taken...
but all im looking for is the difference in stoping disstances and size diference of the rotors and calipers...
i know and understand all of the factors that effect these.
i need a brake upgrade as i am gowing 2 put a rb30det in2 my cefiro, as i got the cef with a rb20E (2ltr vl motor) its brakes arnt up 2 standard with ther power output that im gowing 2 b putting out...
thx, and im sorry again...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
