Could anyone suggest a Tuner/Mechanic in brisy area that is knowledgeable, trustworthy and reasonable if that is possible?? I'm sure thats not to much to ask!
Just bought a 33 GTR from japanese auctions and will arrive in 2-3months and would like to find a reliable mechanic/tuner in the area.
personal expeience and feedback, negative or positive would be great. private message me if want to remain anonomous....Thanks All!!
https://www.sau.com.au/forums/topic/425514-brisbane-tunersmechanics-for-gtrs/
Gavin Woods is the best Nissan tuner/mechanic around in my opinion, he actually drives a R33 GTR , it was previously setup for targa Tasmania,
He will know what to do with your GTR, and you wont get ripped off or stuffed around, a great guy to deal with too
Edited by AngryRBGTX
Maybe to others but the 2 I will bring mine to are both in Gold Coast.
Gavin Wood or Matt Spry.
Gavin's pretty well located as you can go for a walk around Harbour Town when he is tuning your car.
are there no good tuners in brisbane though?
so far without contacting anyone im thinking Dan @ ERD in Yatala from reading past posts or Gavin at Autotech from this and past posts plus the harbour town thing sounds great, take the misses there to blind the fact im spend another thousand on my skyline :whistling: ...booyeah!! cheers Brandon!!
Thanks for feedback
Yea Dan's closed. Dan used to do majority of my mechanical work but Hi-Power's got my business now. Honest and easy to deal with.
You might want to call Autotech and check because I recalled someone from another thread mentioned something about him and Matty Spry working together. He tuned mine ages ago and I didnt have another since.
Thanks for feedback
Gavin uses the dyno at Hi-Power, If you ask he may let you in the dyno room to watch, I watched mine in the dyno room and he talked me through what was happening , its awesome standing next to the car
while its flat out on the dyno :yes:
Lol its freaky to a degree.... Knowing your car is on the limit and asking in the back of your mind "Did i tighten that up"? haha
Even with ear muffs on mine is wild, you can feel it as it screams :woot:
haha, yeah I know what you mean, last time I was worried cause the I put the cams in myself and with it being all stock engine..
yeah like a wild animal, mine was really lumpy until the tune was finished, the V8 boys came out to see what was doing, and gave it the nod, reluctantly lol... :yes:
No way I would let my car be dyno'd without being in the room. I have saved my engine, and a few others by simply checking it after each run, making sure there are no leaks, smoke, loose hoses etc.
That said it's weird having someone rev the crap out of your car on rollers, the first time you will probably shit bricks worrying it will jump off or explode. (mine has done both of these things.) :P
yeah i think that is what happened at the Tech Night we had in NSW a month ago, a lot of first timers in the dyno cell :D
Wait, yours has jumped off and exploded? Remind me never to go near you when operating a dyno :laugh:
With this sort of power, if they don't strap the car down really well, it can snap the straps or bend the hooks which is what happened at the SAU dyno day a few years ago, the car jumped off the back when he hit the brakes. There were 4 of us trying to hold the back of the car so it didn't come right off the dyno.
I also had the cooling system explode when the head gasket let go, boiling hot coolant went everywhere.
You definitely need to be on the ball, and I can see why most workshops won't let customers in the room for safety reasons.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
