Response required by Noon on Sat 25th! PM's received after that time will NOT be included in the club pointscore.
If you are on this list, please send me a PM with your full REAL name so I can complete the club point score.
533 RYC
aaronjod
arrydjay
blackjack404
CLNSKY
darksky34
DC33VN
donut_kng
dori34
eagle_hawk
FeZ25
G3TFKD
GTR_77
ianjb
intune
Is128
JimmyRikard
MaikuL
megzz
Mick's Dad
Mitch_Rona
MsR
n11smo
nick_7g
PRO_32
roadworia
rs88
skylinekido
Spring&WateR
squareznboxez
supanoodle
twotwisted
Victory
vorse
Watchamacallit
xntrq
If you are one of the results listed from the Dyno day please PM me with which one is your's.
http://www.skylinesaustralia.com/forums/topic/415240-dyno-day-unigroup-wrap-up-thread/?p=6660567
https://www.sau.com.au/forums/topic/425800-point-score-request-urgent/
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
