Hi guys I've had my skyline close to 3 months now and so far i'm enjoying it. It's my second car and only turbo i've owned. 130k kms on the clock but who knows if this is true :unsure: everything stock apart from turbo back exhaust and apexi coilovers. Looking to do a few performance mods over the months. Hoping to join the NSW crew soon :rolleyes::cheers:
https://www.sau.com.au/forums/topic/425968-new-gtst-owner/
welcome.
nsw crew are pretty good.
Where abouts are you located?
if youre around sydney and free the long weekend monday, come to our texi(skids) day to have a look and a chat.
watching is free.
check out the EVENTS thread in the NSW section.
any pics of your ride?
https://www.sau.com.au/forums/topic/425968-new-gtst-owner/#findComment-6867699
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
