Heya, i've got a few R33 & general performance parts for sale here in Sydney:
Pickup is fine or I can post them anywhere !
1. Apexi PowerFC & hand controller, suit R33 Skyline Gts-t - $950 ono
post-35556-0-66107500-1369714038_thumb.jpg post-35556-0-24387300-1369714045_thumb.jpg
2. Set of 6x Splitfire SF-DIS-001 coilpacks - $400 ono
Suits Series 1 R33 Gts-t, R32 Gts-t , R32 & R33 GTR
3. Genuine Z32 Air flow meter & Tomei plug. - $200 ono
AFM is in great condition, both mesh sides have no damage. The plug has a small piece chipped off one side but still connects up just fine
4. 60mm HKS boost gauge, includes mounting bracket - $60 ono
5. Hybrid Electronic Boost controller, includes all wiring & the boost sensor - $150 ono
6. Apexi pod filter, great condition. Bolts up to most/all Nissan air flow meters. Includes gasket - $40 ono
7. Auto meter Pro comp air fuel ratio gauge (narrowband) - $50 ono
8. 52mm Alloy / aluminium radiator to suit R32 Gts-t - $100
PM me or reply here if you're keen on anything.
  • 3 weeks later...
Is the Z32 afm still for sale? If so, sms me on 0434838157 thanks and we can work something out, I'm from SA so we will need to factor in freight and payment options. Cheers, Kevin
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
