Got a few turbos lying around, need to move them.
Will include below parts with each one of them. Making them a real bang for the buck for garage build. PM me if have any questions.
Delivery: 7-10 days by EMS
With every turbo I will include 1x -4AN Oil Feed and -10AN Oil return kit + 1x 3-inch V-band kit
Borg Warner
Borg Warner S362 T4 TS .98AR Compressor Size: 7 blade 62mm/83mm Turbine size: 75mm/68mm Compressor flow: 69lbs/min
mmexport1355296579579_zps5a10d065.jpgmmexport1355296535451_zpse49fea67.jpgmmexport1355296573158_zps24e1fa57.jpg
Genuine brand new in box
Journal bearing (not ball bearing!) More reliable and rebuildable. Barely noticeable spool difference when wideopen throttle compared to bb.
Oil cooled centre core with 360degree thrust bearing
Price: AUD760 Delivered to your door with AN Fitting Oil Feed/Return kit and 3-inch V-band kit included
Pay via paypal
PM me for details
Open to reasonable offers
HOLSET
Holset HX30 Singlescroll T3 9cm(.62AR) Compressor Size: 49mm/73mm Turbine size: 65mm/52mm Compressor flow: 0.35kg/s or 46.2lbs/min
Great for RB20/RB25
(if want special 10cm twinscroll T3 housing add extra AUD125(new))
Holset HE351 (HX35/40 hybrid) 650hp+ beast T3 TS 12cm(.78AR) Twinscroll T3 External gate housing 12cm (.78AR) 60mm inducer 86mm exducer 7 blade Holset Super HX40 Compressor flow: ~69lbs/min HX35/HE351 Turbine size: 70mm/60mm
(If you want other turbine housing like T3 10cm TS Internal Gate, T3 12 cm external gate, T3 14cm TS Internal gate, I can get one for extra AUD125 (new))
If you want to see the amazing potential of a HX40 compressor wheel with a smaller than usual turbine housing on it, take a look at this car- Almost 700bhp AT THE WHEELS from a 2ltr Mitsubishi 4G63 (Evo) engine http://www.dsmtuners...2whp-573tq.html
Price: AUD760 (HX30 for AUD735) Delivered to your door with AN Fitting Oil Feed/Return kit and 3-inch V-band kit included
Pay via paypal or wu
PM me for details
Compressor Cast v-band elbows 2.5inch inlet/3inch outlet
Price: AUD35/PCS (Only applicable with turbocarger purchase)
RB special turbo stainless steel manifolds
- Custom made
Turbo inlet flange: T2/T3/T4/T6 Trust/Mitsu 3bolt flange and others
SUS304 stainless steel
3mm pipe thickness
38/42mm runner internal diameter
winscroll or singlesrcoll, single or twin gate configuration
3mm thick flanges, guranteed to not warp and leak
Many Top Asian drifters run those manifolds. With great results and second to none reliability
22412_10152249206820304_549152769_n_zps1Photo016_zps4260efdd.jpg919318_10200324556730189_282945617_o_zps459869_10200324558130224_1435364916_o_zp
Price: RB20/25/26/AUD990 delivered to your door by EMS
PM me for special offer on combo
Edited by robots
With the holsets what are the bottom 2 holsets? You have the hx35 the hx35/40/he351. Then another two displayed? What would the he351 spool like on a built and cammed rb25? Or would the borgwarner be the go? Would full boost be in before 4500rpm?
Answered via PM. Bottom two are just two HE351s with cast elbows and 12cm non-gated housing. Turbo is HE351 which is basicallly HX35/40 hybrid from factory.
Edited by robots
  • Like 1
  • 2 months later...
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
