So, I just ordered a rear Cusco 1.5WAY LSD centre for my car today. Got it for a price I couldn't walk away from.
This means I ALMOST have my driveline sorted how I want it to be;
-Evo 8RS 5sp Gearbox (requires overhaul, gearset shot peened, nitrided, replacement 5th gear / 0.825 ratio, replacement final drive - HKS 4.11)
-Front Cusco 1way LSD (requires overhaul and reset)
-Rear Cusco 1.5way LSD (requires removal of AYC spider gears in rear diff housing)
I have everything either here or ordered, except for the 5th gear. The reason for the change is that the standard box comes with a 0.761 5th gear ratio, which creates too much of an RPM drop. So, a replacement 0.825 should be PERFECT.
  • 4 weeks later...
Another juicy photo for you kids playing at home....
4G63
Nitto 94mm Billet Crank
Nitto 153mm Forged Rods
Nitto/JE 86mm Forged Pistons
GSC CNC Ported MIVEC Head
Toxic-Fab Exhaust Manifold with 1.5" Runners
1491056_10151882807516888_1128558319_n.j
Edited by Tonba
  • 3 months later...
  • 4 weeks later...
^ Fine, Fine...
A few quick updates.
BODY
  • Front guards WERE complete. We have decided to modify them. They have been reshaped and are looking AWESOME. Very unique. The front end is currently so wide, that my 18x10.5" +22 rims w/ 15mm spacers are TOO SMALL. I need more offset.
  • 1500mm Type 5 Voltex GT Wing SOLD and is now being replaced with a 1700mm version of the same wing but with 40mm stand extensions.
  • Evo 9 Rear Bar Installed
  • Work on custom rear guards has started
  • Work on custom front bar has started
  • I was going to swap the bonnet for a Voltex unit, but I am undecided. At the moment there is an 8 week wait on the bonnet if I was to swap it out...
ENGINE
  • Engine has been complete and on the stand for a while now.
  • Debating about swapping my FP HTA Black out for a EFR8374.
CHASSIS / SUSPENSION
  • Currently considering ordering Racefab front and rear chromoly subframes, and chromoly north south bar. If I DO go down this path, it will certainly stiffen up the chassis a lot more, and will drop approx. 30+kg from the car.
  • Currently Talking to Road2Race about chassis and suspension setup.
So, I have been doing some calculations, and playing with the BW Matchbot to see how an EFR8374 with T4 1.05 A/R TS housing would go on my car, and this is what I have come up with. I believe 36psi can be all in around 4,300 - 4,400rpm, possibly earlier.
This particular one is daily and possible 'time-attack' mode but I feel that the intercooler would cop too much heat soak on this boost pressure which would be detrimental to the engine and performance over a lap. This is based on 15psi (1 BAR) @ 4,000 ramping to 36psi (2.5 BAR) from 4,500rpm to 8,000rpm)
http://www.turbos.bwauto.com/aftermarket/matchbot/index.html#version=1.3&displacement=2.185&CID=133.3287&altitude=500&baro=14.502&aat=85&turboconfig=1&compressor=83s75&pt1_rpm=4000&pt1_ve=90&pt1_boost=15&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.25&pt1_mbp=0.5&pt1_ce=65&pt1_te=75&pt1_egt=1700&pt1_ter=1.53&pt1_pw=5.31&pt1_bsfc=0.43&pt1_afr=13.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=4500&pt2_ve=98&pt2_boost=36&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.5&pt2_mbp=1&pt2_ce=70&pt2_te=73&pt2_egt=1600&pt2_ter=2.39&pt2_pw=9.07&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=5000&pt3_ve=103&pt3_boost=36&pt3_ie=95&pt3_filres=0.12&pt3_ipd=1&pt3_mbp=1.3&pt3_ce=73.5&pt3_te=72&pt3_egt=1600&pt3_ter=2.52&pt3_pw=15.46&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=6000&pt4_ve=105&pt4_boost=36&pt4_ie=92&pt4_filres=0.15&pt4_ipd=1.5&pt4_mbp=1.5&pt4_ce=73.5&pt4_te=71&pt4_egt=1600&pt4_ter=2.79&pt4_pw=20.95&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=7000&pt5_ve=107&pt5_boost=36&pt5_ie=90&pt5_filres=0.18&pt5_ipd=1.5&pt5_mbp=1.8&pt5_ce=71.5&pt5_te=70&pt5_egt=1600&pt5_ter=3.09&pt5_pw=23.96&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=8000&pt6_ve=103&pt6_boost=36&pt6_ie=90&pt6_filres=0.2&pt6_ipd=1.5&pt6_mbp=2&pt6_ce=65&pt6_te=70&pt6_egt=1600&pt6_ter=3.41&pt6_pw=22.06&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92044&
I have also done a 'Circuit' model based on a maximum of 26psi.
http://www.turbos.bwauto.com/aftermarket/matchbot/index.html#version=1.3&displacement=2.185&CID=133.3287&altitude=500&baro=14.502&aat=85&turboconfig=1&compressor=83s75&pt1_rpm=4000&pt1_ve=90&pt1_boost=15&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.25&pt1_mbp=0.5&pt1_ce=65&pt1_te=75&pt1_egt=1700&pt1_ter=1.53&pt1_pw=5.31&pt1_bsfc=0.43&pt1_afr=13.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=4500&pt2_ve=98&pt2_boost=26&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.5&pt2_mbp=1&pt2_ce=70&pt2_te=73&pt2_egt=1600&pt2_ter=1.98&pt2_pw=9.46&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=5000&pt3_ve=103&pt3_boost=26&pt3_ie=95&pt3_filres=0.12&pt3_ipd=1&pt3_mbp=1.3&pt3_ce=73.5&pt3_te=72&pt3_egt=1600&pt3_ter=2.07&pt3_pw=15.66&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=6000&pt4_ve=105&pt4_boost=26&pt4_ie=92&pt4_filres=0.15&pt4_ipd=1.5&pt4_mbp=1.5&pt4_ce=73.5&pt4_te=71&pt4_egt=1600&pt4_ter=2.27&pt4_pw=22.05&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=7000&pt5_ve=107&pt5_boost=26&pt5_ie=90&pt5_filres=0.18&pt5_ipd=1.5&pt5_mbp=1.8&pt5_ce=71.5&pt5_te=70&pt5_egt=1600&pt5_ter=2.47&pt5_pw=25.38&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=8000&pt6_ve=103&pt6_boost=26&pt6_ie=90&pt6_filres=0.2&pt6_ipd=1.5&pt6_mbp=2&pt6_ce=65&pt6_te=70&pt6_egt=1600&pt6_ter=2.7&pt6_pw=24.35&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92044&
And last one. A 'Kill-Mode' for dyno runs or if I want to take to the drags. This is based on 15psi (1 BAR) @ 4,000 ramping to 45psi (3.1 BAR) from 4,500rpm to 6,000rpm, then ramping down to 40psi (2.75 BAR) by 7,000rpm finally ramping down to 36psi (2.5 BAR) at 8,000rpm. The engine is built with the best components, so it has no problem taking that type of boost.
Yes - The matchbot presents a calculated torque of over 850+ nm between 4500 and 6000rpm. On a 2.2ltr 4cyl?!! WHAT!
http://www.turbos.bwauto.com/aftermarket/matchbot/index.html#version=1.3&displacement=2.185&CID=133.3287&altitude=500&baro=14.502&aat=85&turboconfig=1&compressor=83s75&pt1_rpm=4000&pt1_ve=90&pt1_boost=15&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.25&pt1_mbp=0.5&pt1_ce=65&pt1_te=75&pt1_egt=1700&pt1_ter=1.53&pt1_pw=5.31&pt1_bsfc=0.43&pt1_afr=13.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=4500&pt2_ve=98&pt2_boost=45&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.5&pt2_mbp=1&pt2_ce=70&pt2_te=73&pt2_egt=1600&pt2_ter=2.79&pt2_pw=8.62&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=5000&pt3_ve=103&pt3_boost=45&pt3_ie=95&pt3_filres=0.12&pt3_ipd=1&pt3_mbp=1.3&pt3_ce=73.5&pt3_te=72&pt3_egt=1600&pt3_ter=2.97&pt3_pw=15.5&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=6000&pt4_ve=105&pt4_boost=45&pt4_ie=92&pt4_filres=0.15&pt4_ipd=1.5&pt4_mbp=1.5&pt4_ce=73.5&pt4_te=71&pt4_egt=1600&pt4_ter=3.29&pt4_pw=20.01&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=7000&pt5_ve=107&pt5_boost=40&pt5_ie=90&pt5_filres=0.18&pt5_ipd=1.5&pt5_mbp=1.8&pt5_ce=71.5&pt5_te=70&pt5_egt=1600&pt5_ter=3.34&pt5_pw=23.22&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=8000&pt6_ve=103&pt6_boost=36&pt6_ie=90&pt6_filres=0.2&pt6_ipd=1.5&pt6_mbp=2&pt6_ce=65&pt6_te=70&pt6_egt=1600&pt6_ter=3.4&pt6_pw=21.74&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92044&
Edited by Tonba
well done on the initial matchbot setup, i like the boost taper and backpressure looks within on-point. where did you get those VE numbers from? my only comment would be to tweak the compressor efficiencies a little better according to the map plot. Both in the real world, and on matchbot - the extra 10% displacement to 2.2L makes a big difference for evo motors with aggressive spooling turbos. I run an 8374 on my 2.0L and while it is a lot of fun, i wish there was a little more displacement as it would spool even quicker and stay out of surge in the lower rpm. Since you want it to be a street car with ac and dont want to notch the gearbox, i really suggest that you consider EFR7670 1.05 a/r
  • 7 months later...
Hey everyone...
A LOT has changed in the last 7-8 months and the car has taken on more of a track focus rather then street.
I have started a web page (http://akracing.me) and facebook page (http://www.facebook.com/AlexKingRacing) so that it is easier for people to follow the builds progress (easier to post in one place!)
As a summary;
  • Everything to do with A/C and heater has been removed.
  • I have purchased a EFR8374 with a T4 1.05 A/R rear on it.
  • I have just fabricated a 6pt roll cage
  • Installed a Velo Apex Seat (hans compatible)
  • Spare wheel well removed and replaced with alloy flat floor
  • Wiring harness has been stripped down and all redundant wiring gone.
  • Door Cards are gone, and I am currently making some alloy replacements
  • Focus on Aero rather then just wide body..
  • New Front brakes are being made, ready to be bolted on in Jan
  • Fuel system has gone and now going to a surge tank setup (rather then in tank)
Thats about all I can think of!
I hope everyone had a fantastic Xmas!
  • 5 months later...
  • 4 months later...
Some pictures of the car in its first public appearance on the weekend at World Time Attack Challenge, Sydney (Australia). Huge thanks to all who showed up to have a good look at it. Thanks to J_Hui for the beautiful photographs.
A shout-out to Arise Autobody for all the hard work they put in to get it ready, make sure to check them out on facebook to checkout all the other amazing work they do - www.facebook.com/ariseautobody
Thanks to my business Partner Tim for helping me get it together, and helping on the day - www.facebook.com/speedruninc
12112139_1050208048355904_87885346799140
12112468_1050209661689076_67315216574760
12096121_1050208098355899_82510555352326
12107201_1050208108355898_15267766850043
12108276_1050208131689229_14009102350384
12112198_1050208055022570_41154102960600
12079098_1050208051689237_37651402277071
12105710_1050208155022560_28177072255603
12066069_1050208191689223_29305205155896
  • Like 3
  • 4 weeks later...
Hey All!
J_Hui Design / Photography finally got around to releasing the photos he took of my car at WTAC. I realize there may be some duplicates of what I have already posted, but I am too lazy to filter those out.. haha.*
12247696_1061383363905039_34684947017363
12240331_1061383437238365_38327888861378
12240346_1061382510571791_53935208656837
12244836_1061383067238402_82335466326292
12247896_1061382707238438_21664919643233
12189241_1061382747238434_34703573426821
12244694_1061382817238427_61510879702898
12184231_1061382847238424_25822480545991
12096390_1050208175022558_72385433055424
11231217_1061383397238369_70590616695988
12238194_1061383323905043_61920883905344
12239231_1061383280571714_34647325089352
12240956_1061382593905116_83850062362684
12240987_1061382623905113_79494811890641
12247701_1061383233905052_60469353132143
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
