S A U - N S W Tech Night For Members 5Th July - Servicing, Blue Slips, Eng Certificates
  • Replies 129
Watch out for that honky, he be burnin!
See you tonight. Think I'll drive my lil shitbox, considering the parking situation.
Which one? :ph34r:
Yeh, Mat has all sorts of contagious ailments but he is still going! :P
I dont want to know how you know this lol, and no worries Terry.
I think i might be allergic to all SAU tech nights. This is the second i havent been able to attend :(
Another successful night.
Thank you to the Execs, and JLM for their hospitality. A frank and open discussion on the ins and outs of the industry, interactions with government, and law enforcement was interesting. Lots of interesting parts, motors, and cars to cast the eye over, as per usual.
Enjoyed "fish sticks" as geeteetee put it, served on the bonnet of a WTAC contender. Certainly novel.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
