very nice. if i had $100k cash I would buy it. i don't do finance.
Buy a 31
Oh wait... :P
P.S when are you going to do a build thead? :)
yeah yeah, I know. I need to get some time to go around to my mums place and start the damned thing. haven't done anything with it and that includes taking any pictures.
for $100k you could buy much nicer cars.
Do a write up for the piny cup!
