Will be there for Breaky, not driving though. Brakes won't be done by then. :(
You kind of need brakes in an auto around lakeside.
This, engine braking results in fuarked autos and the equivalent of pulling the handbrake on at 100ks an hour
not for happy laps
Yes for happy laps :dry:
Have just emailed off the appropriate form and receipt.
Fingers crossed for a nice sunny morning!
See you there!
(Can my passenger pay on the day?)
Received. Thanks matey!
#@Cadmoon can chime in on payment
He can also explain why out of the three applications I saw, two were for Hondas. :/
Count me in, I'll be there with the Legnum since my trip to the Toowoomba races just got cancelled.
Didn't even realise I got a membership card with all the SAUQld stickers I got (which I am yet to find the right place to put on my car...) had to do a bit of searching
Will come on sunday 2 spectate if its fine haven't had the car out in 3months..... Also need 2 pay membership and for the club t-shirts if this is possible can some1 tell me???
Come out mate. You can pay for all that on the day however if you could wire the cash through instead, it would make life so much easier!
let us know if you're coming so that we can bring shirts for you.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
