dam was going to start this last night. beat me too it.
Online is really good, if you can get a good pit. most of online now is just a demolition derby, so i only race online with people i know these days.
oh, did i mention the people already at level 30 with the fastest cars? doesnt make online all that fun.
i'm happy to race with any of you guys, so give us a yell when you want to have a run and i'll jump on ID: -=GA=- CLK-GTR
and for those who havent played it before, heres a video from this mornings antics
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6884068
I hardly ever buy games straight up, hire them first and see if i'll play it more than the few days i've got it hired.
Future exceptions will be new GTA and possible that end of days when i get some spare cash.
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6929171
Hmmm was thinking about buying this, but after hearing this and not having a wheel setup at the moment, I think I'll give it a miss :(
Most people I know are actually faster on a controller......Or so I have discovered. things like Catching your car when someone tries a PIT maneuver is alot easier on controller.
It is a very frustrating game, but very fast and often very fun.
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6930794
its really fun and close racing when your in a pit full of white/green racers..... its frustrating when your in a pit full of yellow/organge racers :yes:
also, soundtrack was released today aswell
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6930907
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
