dam was going to start this last night. beat me too it.
Online is really good, if you can get a good pit. most of online now is just a demolition derby, so i only race online with people i know these days.
oh, did i mention the people already at level 30 with the fastest cars? doesnt make online all that fun.
i'm happy to race with any of you guys, so give us a yell when you want to have a run and i'll jump on ID: -=GA=- CLK-GTR
and for those who havent played it before, heres a video from this mornings antics
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6884068
I hardly ever buy games straight up, hire them first and see if i'll play it more than the few days i've got it hired.
Future exceptions will be new GTA and possible that end of days when i get some spare cash.
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6929171
Hmmm was thinking about buying this, but after hearing this and not having a wheel setup at the moment, I think I'll give it a miss :(
Most people I know are actually faster on a controller......Or so I have discovered. things like Catching your car when someone tries a PIT maneuver is alot easier on controller.
It is a very frustrating game, but very fast and often very fun.
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6930794
its really fun and close racing when your in a pit full of white/green racers..... its frustrating when your in a pit full of yellow/organge racers :yes:
also, soundtrack was released today aswell
https://www.sau.com.au/forums/topic/426635-grid2/#findComment-6930907
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
