Hey guys, i'm pulling apart this engine as it was blowing smoke, suspected headgasket but it looked fine when pulled apart.. Cracked piston and/or blown rings? The engine had approx 145,000 km on the clock - pretty much everything is for sale:
Have added a few photos below, more available on request ! If you need any random parts or hoses off it let me know. Located in Sydney for pickup or I can post anywhere
Rb25det head - includes rocker covers, cams, valves, etc etc, everything except the exhaust cam - $300
HKS exhaust cam gear - $150
upper and lower timing belt / cam covers - $80
CAS - $80
intake manifold - $50
harmonic balancer - $80
sump, oil pickup & all bolts - $80
oil dipstick - $20
AAC idle valve - $75
S2 coilpacks - $100 / full set
S2 coilpack loom - $50
standard turbo oil & water lines + banjo bolts - $50
standard injectors & fuel rail + FPR - $100
Alternator - $80
P/S pump - $100
A/C pump - $100
Anything else.... chuck me a PM or reply here !
https://www.sau.com.au/forums/topic/427115-stripping-complete-rb25det-engine/
  • 1 month later...
Hey buddy interested in turbo lines plus all banjo bolts, If you have the turbo outlet compressor pipe, and coil packs plz. Price and I'm from melbourne
  • 3 weeks later...
do you have the vct head oil drain line?
Sorry late reply.. i've still got it. if you're keen PM me !
Hi mate is the head series 2??? Can you please SMS me on 0422193418 thank you
Sorry mate the head is sold
hey mate just wondering if you still have the oil and water lines with banjo bolts still available?
Yep still have them, PM sent
Do something on the cross pipe, bov, intake manifold, turbo lines and banjo bolts? $$
Pm me ur best price pickup on them all!
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
