Hey Guys,
Need help I'm having trouble getting the spoiler off my r34 I have undone the four bolts in the boot and snapped the two plastic things in the middle but can't get it off seems stuck tried to pull it but it won't come off. Could anyone that has done this before please advise?
Thanks Dion
https://www.sau.com.au/forums/topic/427153-r34-rear-spoiler/
Double sided tape.
Re-attach the bolts about half way to prevent the wing popping off and scratching the bootlid after the next step.
Push up on the spoiler (away from the bootlid) and with the other hand slide a thin stencil knife around the edge to slice the tape, presto!
Use metho, or any other sort of adhesive remover to remove the left over double sided tape residue
Finally got it off last night. But left shit loads of tape on the and two ugly spots on my boot. Tried to clean the tape off got half of it off gonna do the rest tonight. Now gotta start thinking about what I'm gonna do about the holes any ideas?
If you really don't plan on putting another wing on, have the holes welded over and the boot resprayed. Do not have them fibreglassed as they will crack over time.
Short term, put a sticker over the top to stop water seeping it, and go to bunnings or the likes and get a rubber grommet large enough to plug the hole tightly.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
