Another one stolen from Robina, this is getting stupid why can't people down there jsut learn to stop touching other peoples pride and joys, hope she's found fast and in one piece.
Have past the info onto Stolen Imports Australia on Facebook, been having quite a bit of luck recovering stolen cars through them.
They may need more info like mods, distinct features etc to make it easier to spot.
:( well really you shouldn't because the scum bags shouldn't have touched it. i think that makes about 6 stolen from robina in the past few weeks. What's the plan part out and start a fresh with another or is it repairable?
Good idea the sooner the pic up the sooner the repairs, I wish you all the best and luck getting her put back together and hopefullt she comes out a tougher meaner machine :P
I really don't want to give false information but I DID see a white 33 similar to this (didn't really take notice) they hopped off at the arundel exit on the M1 (exit 66)
Around 7:05 this morning
Nevermind just read that the car was found... Smashed :( sorry to hear mate..
Edited by Zrobe
  • Like 1
You should be able to get some sort of compensastion due to being a "Victim of Crime". There is a few different descriptions under Victim of Crime but hey there may just be something there for you....even if its a hug and some warm words of support lol.
Just google "QLD Victim of Crime Compensation".....hope it helps because i have been there aswell....$18500 worth of R32 down the drain.
Go See Chris Rogers from Audio Express, His anti-theft work is second to none and he works for reasonable rates.
If Chris fits the gear the only way they are stealing it is on a trailer with it screaming it's tits off.
That's how I got that girl back to mine :P
Yeah payed $300 for towing then $100 to get it back to the gc $300 for my front bar that was smashed + now ignition damage brakes are gone and the car is unstaible power is being lost so havent got the final bill yet :( its horrible but got the car detailed shes starting to look beter than before ill post pics wen shes all done :)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
