Spewing I am guna miss this as my car still isnt ready :verymad:
Jump in with someone else? Get too meet some good people anyway?
On that note, ill try get my car limping on Saturday for the run, however its got a few things i havent fixed so there will be no spirited driving from me, i am volunteering to go ahead in sections and pull up and do photos and video for you guys, i will need someone to lend me a radio if we do so i can get you to space out a bit to make it easier! Everyone loves a good rolling shot!
Ill see how things pan out. Id love to go, but i also have to come up from wollongong, so would rather be in my own car.
Yep fair call mate! We run a few events up here as the boys love cruising :yes:
ive got a 2way you can borrow.
but im doing the half putty meet up.
Might sort it with you on the day! Will have a phone but of course as we wil all be abiding by the road rules i wont be using it :ph34r:
WTF is it with you and your car
Makes great numbers then breaks
Gets fixed and makes better numbers and is now broken again?
I think I've got my 7D car mount sorted, so some highway rolling videos should come out awesome!
What channel are we using on the 2way? It may have been mentioned earlier, but CBF going back.
sounds good mat. even if you leave earlier thrn us at stops amd pull over and well zoom past. stay spaced until we see you :)
Yep that is the plan!
It hasnt broken, it just hasnt been fixed since the last time i damaged it! Its suspension and brakes, nothing to do with the rest of the car ya clown :P
its karma for giving me shit :D
That is never going to change!
Build it, tune it, race it, break it, fix it, repeat it.
I like this!
Nice one mate! Should be good!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
