theponyremark Posted June 21, 2013 Share Posted June 21, 2013 Hi all, I've noticed over time (as with my then-tarnished clear coat), that the black plastic window trim (as I could best describe it), has tarnished under the Australian sun. I'd say at least 40% of the trim is "patchy". Is there a part number or something to remediate this problem? Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/ Share on other sites More sharing options...
Sinista32 Posted June 21, 2013 Share Posted June 21, 2013 On the 32 it's called a weather strip retainer. ($366). Someone maybe able to post the part number for the 34 Have you tried any Meguairs external trim cleaner? Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6899655 Share on other sites More sharing options...
theponyremark Posted June 21, 2013 Author Share Posted June 21, 2013 Hey Sinista32, thanks for that! I think it should be the same name for the R34. I haven't tried Meguiar's external trim products, seeing that it's plastic that's tarnished, I should give that a try before spending $366. Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6899708 Share on other sites More sharing options...
theponyremark Posted June 21, 2013 Author Share Posted June 21, 2013 Which of the two products would be better to use to polish that trim? http://www.meguiars.com.au/products/car-care/glass-clear-plastic-and-exterior-trim/gold-class-trim-detailer/ - or - http://www.meguiars.com.au/products/car-care/glass-clear-plastic-and-exterior-trim/ultimate-protectant/ Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6899716 Share on other sites More sharing options...
Sinista32 Posted June 21, 2013 Share Posted June 21, 2013 Externally I use the gold class trim detailer. Looks like clag glue but does wonders. Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6899827 Share on other sites More sharing options...
darksky34 Posted June 21, 2013 Share Posted June 21, 2013 i've used the trim detailer but that's only temporary, you'll find that you need to redo it every month-2 months. i'd actually like to try the protectant as that says it is a restorer...but who knows! Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6899881 Share on other sites More sharing options...
Sinista32 Posted June 21, 2013 Share Posted June 21, 2013 used both and your right they do need re-doing. Sometimes they become patchy because the wind deflector has been removed damaging the finish. - double sided tape can ruin the finish or it could just be rub from the wind deflector. If it's never had a wind deflector on it should be fine with a clean. Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6900733 Share on other sites More sharing options...
mungy Posted June 22, 2013 Share Posted June 22, 2013 Unfortunatley its just how plastic is, it will never look the same again if its faded in some spots. best you can do is take em off the car and try to re-clear coat them. but it may just ruin them, if you chose to buy some i have a set here in SA in good condition off a 98 GTT, unfortunatley at the rear its not just the plastic that part is attached to the quater glass. Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6900799 Share on other sites More sharing options...
theponyremark Posted June 23, 2013 Author Share Posted June 23, 2013 Thanks guys for your input. Very valuable information I tried both Megiuar's products which did not change from it's original state. I think I need to wet sand it back with fine grit paper and then spray paint and re-clear coat them. $366 is still too steep for a bit of trim and hopefully the DIY job would only cost me a few days of manual labour. Looks like I will need to buy couple of extra 3M edge masking tape. Thanks for the offer mungy. I will definitely buy it off you if this goes wrong Link to comment https://www.sau.com.au/forums/topic/427359-whats-this-window-trim-called/#findComment-6902483 Share on other sites More sharing options...
