That's exactly what i said. Take it for a day out at basky and you will forget about selling it pretty quickly. On that note i am hopefully going to have my car tuned next month and will be organizing a quiet track day for a bit of a "run in/learn how to drive your car again" session if anyone is interested. ie. jack lol.
I'll be down in tassie on the 27th-28th of July and should be at the track on the 28th if anyone else is keen ;)
Wtf why are basic car trailers like 4-5k. That's like quarter of a Evo 8. That shits not happening
That's why I ended up going for one of Az's trailers, not much more than a stock standard POS trailer, but 10x better by far. We saw a number of wooden based trailers which were still a fortune, and basically useless and horrible for what we wanted.
At least the resale value should still be pretty high
Az's trailers sound nice but I simply can't justify it. Brody thinks 2k if we were to build, have a contact on the steel, that's more like it. Might be able to put slide in cage sides on one and use it as a yard trailer also.... Get rid of parents box trailer kill two birds with one stone. But paying 4-5k I won't be.
Well i dropped into pro auto today only to find that they're closed till Thursday!!! So i hope he won't be too busy when he's back and can fit me in cause im keen to get on the track!
Glad to hear you finally got motor back. :yes:
QUESTION - for our local super sprints, hill climbs and time attack event, does a unregistered vehicle require a log booked cage? my Bond cage can't be log booked, I see on the mainland this seems to be the case. all because its not road registered?
  • 4 weeks later...
Just a heads up as some people seemed interested in heading out, I'm all set to go for a track day this Sunday (28th July). Would be good to see some of you guys there :)
Hopefully it doesn't rain too much.. I still don't have windscreen wiper arms!
Clandestine, Rainx is you're friend!! 10 bux a bottle works wonders. I'm still a little way off, have actually got a bit done recently but awaiting for a few things to turn up and still yet to order some others... Made my canards yesterday and today, about 10 hours from start to finish. Thinking October, fingers crossed
Would love to come but turns out when I got my car tuned the other week it still has oil smoke issues on boost which need sorting out. :verymad: Was considering a tester at basky to see exactly how bad the problem is but don't think I'll be ready for sunday.
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
