hey guys i have just put a gtx 3582r and a geddy intake fmi and exhaust on my rb25 i cnt get it to stop idle hunting and running rich i have changed afm 02 sener tps gone over it for vak leak cnt find it im running a staned comp injecters and boost can anyone help thanks
https://www.sau.com.au/forums/topic/427445-need-help/
Either your AAC valve is not installed correctly (electrical/plumbing wise) or you have a vacuum leak somewhere.
Is this a Freddy manifold? If so, do you know that it is straight enough?
Are you running a PFC?
Note that this is a topic that has been posted about a kuntrillion times before and you should have searched.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901674
are yes, but is that a metric or imperial amount
try running around the intake with a can of brake or contact cleaner, or the like, and see if idle changes and that will tell you if there is a leak
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901675
i am new to this site and i havnt realy looked for the posted i will try now thanks
and xklaba i tryed that with contact cleaner didnt change anything and yes it is a greddy plenum if the face was not flat on the head shoudlnt it leak water from the jacket
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901708
thanks GTSboy
even then on 5 psi with this big turbo how would it make it run so rich and idle hunt i have put 3540 on non turbo rb30 and its runs fine.
soon i will be putting my injecters in and cams and comp but there no reason that i can think of why it wouldnt run.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901805
been over it 100 times with water spray and contact spary doesnt change a thing i even pulled the intake off to make sure i have it all plumed up right couldnt fine anything. could a water temp sender do it. but then again it does it when its cold as well.
https://www.sau.com.au/forums/topic/427445-need-help/#findComment-6901868
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
